Author: Subject: ZX6R Throttle Bodies help
aidan46
posted on 20/11/11 at 04:52 PM Reply With Quote
Hi I have a set of throttle bodies from a 2006 ZX6R . It has two sets of butterflies one a the top which is oval in shape then another set further down which are regular round ones. (worked off the throttle cable) Just wondering whats the purpose of having the two sets?
will121
posted on 20/11/11 at 07:54 PM Reply With Quote
Normally inner set is directly controlled by the throttle position with outer controlled by ecu but can't explain why
aidan46
posted on 20/11/11 at 08:44 PM Reply With Quote
Yeah the outer one seems to be attached to a motor on the end of the shaft. Could it be to do with the Idle air control?. Im in the process of putting them on a zetec to be run with a megasquirt ECU.
will121
posted on 20/11/11 at 08:50 PM Reply With Quote
I've fitted gsxr throttle bodies on a zetec which also had twin butterflys I removed the outer ones and blanked them off
aidan46
posted on 20/11/11 at 09:01 PM Reply With Quote
Yeah I was thinking that might be the handiest thing to do!!
Rob Allison
posted on 21/11/11 at 02:27 AM Reply With Quote
You mean these butterflys
I've just removed them and plugged the side holes. There now on a zetec
aidan46
posted on 21/11/11 at 01:16 PM Reply With Quote
Yeah, thats them alright. Have you spaced them out a little to fit your manifold?
Rob Allison
posted on 21/11/11 at 02:19 PM Reply With Quote
Yes. About 45mm or so. Easy to do, just longer bolts to hold it together and spacers. Then extend the lever between the two for the throttle. The fuel rail also needs extending.
aidan46
posted on 21/11/11 at 05:02 PM Reply With Quote
Thanks,
Sounds straight forward enough, except how is the fuel rail extended? do I need a new longer rail connector T piece?
Rob Allison
posted on 21/11/11 at 09:10 PM Reply With Quote
The pipe is 6 or 8mm i just cut and welded a piece in. but you could use copper tube and a T piece soldered in.
aidan46
posted on 21/11/11 at 09:52 PM Reply With Quote
Fair Play Rob thats great help.
