<<  1    2    3  >>
Author: Subject: Mid Engined Gear Linkage Problem
Mr C
posted on 21/11/11 at 09:06 AM Reply With Quote
I'm attempting to design and make my own gearchange mechanism. Its for a subaru gearbox converted into a mid engined configuration. I've currently got as far as the set up shown in the images, albeit the homemade parts have been replaced with machined components. The current problem is the pattern is "upside down" 2nd is where 1st should be and 3rd is where 4th should be. Although I can live with this, I am worried that a wrongly selected gear, resulting in engine damage may occur. So I'm looking for suggestions, thoughts etc, to get the pattern right. Cable change mechanisms do not seem to work well with this box so is not an option. I would prefer to use existing mounting holes etc and the mechanism has to be simple and robust.
I'm hoping I've missed something blindingly simple and hope to be enlightened
[Edited on 21/11/11 by Mr C]
Girl walks into a bar and asks for a double entendre, so the barman gave her one
liam.mccaffrey
posted on 21/11/11 at 09:25 AM Reply With Quote
I have a very similar problem in that I had considered modifying my gear change unit like you have. I think however I am going to risk it though and and turn the volvo gear change unit around and have new control cables made. this will mean my gears will be upside down for a volvo 850. My box was cable operated all along however.
Build Blog
Build Photo Album
rdodger
posted on 21/11/11 at 09:33 AM Reply With Quote
Could you consider using the mechanism from a mid/rear engined car?
On my GTM Libra I used an Elise mechanism when I got rid of the rod change. It does use cable though.
911 could be an option too.
Failing that have you looked at the Ultima rod change?
jack_t
posted on 21/11/11 at 09:55 AM Reply With Quote
Hello matey
i have been following this on your blog, i may have a solution to your problem u2u me your email and ill send u a diagram of what you will have to do
russbost
posted on 21/11/11 at 10:07 AM Reply With Quote
Surely it is simply a matter of changing the relatinship of the pivot & operating rod? At present you have pivot at centre & operating rod below, if you move the operating rod to above the pivot everything will work "backwards" therefore making it the right way round for your installation.
Seems, very straightforward unless I am missing something entirely?
liam.mccaffrey
posted on 21/11/11 at 10:14 AM Reply With Quote
Where might i find a link to your blog.
Originally posted by jack_t
Hello matey
Build Blog
Build Photo Album
jack_t
posted on 21/11/11 at 10:19 AM Reply With Quote
Hello matey
the rod that comes out beneath the car also rotates so the gear stick end needs to stay in that configuration its the gearbox end that needs to change
stevebubs
posted on 21/11/11 at 11:20 AM Reply With Quote
As above - surely it's just a case of shifting a pivot point either at the front or back of the car?
Mr C
posted on 21/11/11 at 11:23 AM Reply With Quote
Thanks all for such a rapid and helpful response, amazing.
My blog is Scoobystorm
The design is based on what I've seen on Ultimas and also a GD setup. The gearbox is originally rod and doesn't like cable particulary because of 5th and reverse being internally strongly spring loaded.
As Jack stated, the rod needs to rotate
Thanks again all.
Mike
posted on 21/11/11 at 12:26 PM Reply With Quote
It depends on the OP's interpretation of "upside down". If 1st is where 2nd should be, and both 1st and second are to the right of 3rd and 4th then this will work. If 1st and 2nd are correctly located to the left of 3rd and 4th, then changing the pivot will fix one problem and introduce another. i.e. does only the push/pull motion need to be reversed, or does both push/pull and rotation of the operating rod need to be reversed?
Mr C
posted on 21/11/11 at 12:41 PM Reply With Quote
Thanks for highlighting this, I did find it difficult to describe succintly, the push pull needs to be reversed, the rotation is currently correct.
current gear pattern
2 4 R
1 3 5
standard pattern
1 3 5
2 4 R
Mr C
posted on 21/11/11 at 01:06 PM Reply With Quote
Jack, U2U sent, thanks, Mike
russbost
posted on 21/11/11 at 01:49 PM Reply With Quote
From the above gear pattern a simple swap of the operating rod/pivot position will do the job.
posted on 21/11/11 at 04:44 PM Reply With Quote
I still don't understand how moving the pivot will reverse only the push/pull and not the rotation? Could you do a quick sketch?
At the moment, standing at the rear end of the car and looking forwards, moving the gear lever left will turn the operating rod clockwise i.e. the rod turns in the opposite direction to the gearlever pivot. Pushing the gearlever forward will move the operating rod backwards. The rotation must be preserved whilst the push/pull motion reversed.
I can't see a simple solution to this without adding additional linkages.
Mr C
posted on 21/11/11 at 05:34 PM Reply With Quote
The linkage moves in the way described and the left right rotation needs to remain the same whilst reversing the push pull operation. The difficulty is keeping the rotation working whilst doing this as Mike states. I was hoping there would be a simple linkage someone might come up with that I could add.
russbost
posted on 21/11/11 at 05:48 PM Reply With Quote
Now in fairness I did say "Seems, very straightforward unless I am missing something entirely?" which I was!
Sorry, should have looked more closely at the pics, I was asssuming it was a twin rod system & you'd only pictured part of it, I didn't look at the third pic where it's more obvious!
I would therefore have to agree that without splitting the 2 motions I can't see an easy way of doing it.
Is this in an SDR storm? Actually doesn't matter whether it is or not as they use that engine & box IIRC, how do they get around the problem, presumably they aren't selling kits where you finish up with a backwards gearshift, so they must have found a way around it???
v8kid
posted on 21/11/11 at 06:12 PM Reply With Quote
If you make the pivot point for your gearstick the bottom set of balljoints and have the actuation rod coming from the top set of balljoints when you push the stick forwards the actuation rod will go forwards instead of backwards.
Or am I missing something too?
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Mr C
posted on 21/11/11 at 06:47 PM Reply With Quote
Hi Russ
Yes it is a V-Storm, The SDR gear change isn't production ready as such. Simon is currently working on a dash mounted cable gear change mechanism and has been for a while. The demo car was not brilliant, being vague at best and the most recent write up in this months CKC was even less complimentary. I'm not convinced it will be a satisfactory mechanism, coupled with the long wait (22 months from date of order) I've decided to cut my losses and do my own thing.
The other option is the mechanism developed by Saker but its untidy looking and probably similar in quality to the one Simon's developing, indeed I understand they now use sequential boxes.
I've thought about modifying the gearchange to do this and will do a rough drawing albeit in powerpoint as I haven't a clue with CAD etc and would appreciate some feedback, if I get it done in a little while I'll post it shortly.
I'm not an engineer, actually a nurse by trade and this being my first build, appreciate any ideas no matter how small or insignificant they may be. as this is my last major hurdle to getting this thing on the road.
Thanks again all.
Mr C
posted on 21/11/11 at 06:50 PM Reply With Quote
Cheers!
Thanks for your response
You would loose the rotation required for the gear change also the ball joints are rod ends so will not allow for the type of movement if I have understood your suggestion.
Mike
fluidslvr
posted on 21/11/11 at 07:37 PM Reply With Quote
this any help to you??
http://www.youtube.com/watch?v=RJZiZfE_IoE&feature=related
http://mkmidi.blogspot.com
russbost
posted on 21/11/11 at 07:42 PM Reply With Quote
Mike
2 suggestions, first would it be possible to split the gearchange into 2 x rods, with one doing the rotation & the other doing the fore/aft motion. Can't be 100% certain looking at your setup from the pics but it looks as tho' you may be able to keep the lower rod to control the rotating motion (which is in the correct plane as it is) tho' you would have to incorporate some sort of "slide" at the rear end to stop from controlling the longitudinal motion & add an upper rod which would do the fore aft?
The other thing I would say is that there is no reason at all why a cable shift should be "wooly" or vague, the original MR2 which is what I use as a donor for the Furore had a fairly precise shift & even controlling it from a position around 3 feet further forward with longer cables we still get a precise shift. I would emphasise tho' that for the car shift we pay about £150 for bespoke cables, which, like the originals are quite beefy. When using a bike engine we just use a teleflex cable, & I've heard of people using teleflex (or morse) cables for car shifts, but personally I never would. However there are plenty of car cables around, which I would think would be long enough for your application without needing modification, might be worth thinking about??
Mr C
posted on 21/11/11 at 08:42 PM Reply With Quote
Russ thanks for your response, very helpful, potentially I would go to two rods if I can't get one to work and its better than the cable option in terms of complexity and use. I'll keep this open as an option. One of the challenges is the routing of rods front to back, there are not many/any options. The other challenge is the 5th/reverse gear which is heavily sprung. This is presenting a challenge for the cable setup according to Jason at scoobybits(posted on exocars) and adjustment is tricky to say the least.
As well as work well the mechanism is on show at the back of the car so I would like it to look good as well (maybe too many asks on my part
I don't know why the cable system is not working as well as you say it should, perhaps Simon Dickens might be able to shed some more light on this. If it did work well and was available I would gladly take it in preference to my own lashup
I've come up with the arrangement below hope it makes sense. The UJ at the bottom of the gearstick would have to be modified to give left/right movement only.
How well would this work given there is no fixed pivot point fore and aft?
jack_t is also thinking about options at the gear box end, thanks Jack, so I'm hopeful we can crack this.
Mr C
posted on 21/11/11 at 09:05 PM Reply With Quote
Russ and all, just done a quick drawing of proposed UJ setup on the end of the gearstick in line with my previous thoughts and suggestions
The back is to the left of the image, hope it makes sense.
Mike
Alan B
posted on 21/11/11 at 09:11 PM Reply With Quote
Any help with this of mine....?
It's a hybrid rod/cable system
[img] gc1
gc1
[/img]
russbost
posted on 21/11/11 at 09:13 PM Reply With Quote
Trying to make quite sure I understand what you have at the moment, between the 2 rod ends in the pic is the lever sitting in a spherical bearing allowing the lever to pivot both fore/aft & side to side?
If I'm understanding your drawing correctly & I have understood what you had originally then it's possible, if you modify the lower joint as you suggest, that it could work, but depending on the length above the lower slide thro' the rod ends I think it quite possible it might "snag" & therefore make the fore/aft shift stick & jam, if you added further support, perhaps another pair of rod ends in front & behind the 2 you already have I guess that might do the trick, it's one of those things that a little trial & error in practice is probably necessary to find an optimum setup.
Although all the gears should then be in the right place, the change might still feel a bit strange as you'd be sliding the gearstick fore & aft instead of the usual action of pivotting it. An interesting conundrum this one!
I would suggest ask Simon what cables he is using as if they are a bit lightweight the problem with that shift may be nothing more than that.
<<  1    2    3  >>
