Author: Subject: weird vibration tin top
mrwibble
posted on 22/11/11 at 01:27 PM Reply With Quote
Help?!
Had a vibration from nearside of car when decelerating at low speed for a few weeks now. started off very occasionally, now I hear it regularly. Past week i've made myself believe its pulling to the right so decided to get underneath it and have a look.
Had a look at the TREs today, I can't tell anythings the matter with them, but i guess you might not?
MOT in July mentioned "slight play in steering" they didn't seem at all worried, but today I can't find any, wondered how the garage would check this?
mookaloid
posted on 22/11/11 at 01:30 PM Reply With Quote
dry cv joint?
jossey
posted on 22/11/11 at 01:33 PM Reply With Quote
goto a open carpark and reverse slowly with the full lock on and see what noise you get you will know if its a CV joint.
Also jack it up and see what play is in it.
it will either be a wishbone or cv joint.
David Johnson
mrwibble
posted on 22/11/11 at 01:41 PM Reply With Quote
certainly no nasty crunching noises as i reverse with lock on, i do this daily. might have to take it somewhere with some ramps.
jossey
posted on 22/11/11 at 01:43 PM Reply With Quote
well thats me out of idea's :O)
beaten by the cube....
David Johnson
mrwibble
posted on 22/11/11 at 01:44 PM Reply With Quote
hah, thanks for the reply though!
Ninehigh
posted on 22/11/11 at 03:36 PM Reply With Quote
I take it you're going in a straight line, but:
What speed does the vibration start, and are you braking, engine braking or coasting?
Not that I'd have a clue but I think someone might be able to shed more light on it
posted on 22/11/11 at 03:37 PM Reply With Quote
Wishbone/track control arm inner bush or outer ball joint ----
hughpinder
posted on 22/11/11 at 03:43 PM Reply With Quote
Whats the tyre wear like? Not the wear limit ridges is it (that just a bit of noise rather than vibration though).
Is it only at low speed?
mrwibble
posted on 22/11/11 at 04:22 PM Reply With Quote
Hi, yes its just slow speed. Engine braking in second I notice it 20-25mph. and only on certain road conditions, seems to happen when downhill. but there is a patch leaving work which i notice it alot. Don't have any issues with tyre wear, although as its pulling to the right now, if its not sorted i think it could later on. plenty of thread on tyres, doesn't seem to me to have the right frequency to be tyre related.
scrappy_7
posted on 22/11/11 at 07:05 PM Reply With Quote
try looking for play in the drop link arms
dray13dad
posted on 22/11/11 at 07:17 PM Reply With Quote
What car is it!!
mrwibble
posted on 22/11/11 at 07:31 PM Reply With Quote
hah! mk1 focus
dray13dad
posted on 22/11/11 at 09:20 PM Reply With Quote
Things to check,
tyres do get eaten on focus (tend to go egg shape and tread lift.check the inner cv joint on n/s tri coupling type of joint with needle roller and they drop out,or if that sort of vibration maybe worth checking o/s driveshaft centre support bearing.
hope this helps.
bertie_bas205
posted on 24/11/11 at 10:09 PM Reply With Quote
Originally posted by mrwibble
hah! mk1 focus
Bushes.....
Or, there is a bearing on one of the driveshafts..... common to go...
Bertie
