Author: Subject: disguising cut edge of fibreglass
jabbahutt
posted on 25/11/11 at 11:34 AM Reply With Quote
Morning all
Quick question for you all. If you have an exposed edge around a hole within a fibreglass panel showing. What's the best way to make it blend with the panel? I can't use edge trim so need to colour the exposed bare fibreglass somehow. The panel is black and wondered what is the best/neatest product to use?
I was thinking of a small pint brush and dabbing paint along the cut panel to disguise it, any better ways?
Thanks as always
Nigel
wicket
posted on 25/11/11 at 11:47 AM Reply With Quote
When I cut the vent apertures in the bonnet I finished the cut edges with fine abrasive and then painted the edge with clear enamel. Looks fine.
Alan M
posted on 25/11/11 at 12:12 PM Reply With Quote
"I was thinking of a small pint brush and dabbing paint along the cut panel to disguise it, any better ways?"
Is a "small pint" similar to a quick pint?
twybrow
posted on 25/11/11 at 01:01 PM Reply With Quote
Use gelcoat (flowcoat) to blend it in with the surrounding black gel (assuming it is a gelcoated panel of course)... for the amoputn you need, you may even be able to get a free sample!
blakep82
posted on 25/11/11 at 01:06 PM Reply With Quote
black permanant marker?
________________________
ReMan
posted on 25/11/11 at 01:49 PM Reply With Quote
Sorry, got to ask why you cant trim it?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jabbahutt
posted on 25/11/11 at 02:05 PM Reply With Quote
To answer your Question Reman I can't use edge trim because I want to attached some folded aluminium to the rear of the cut out level with the edges so can't have anything fouling.
stevebubs
posted on 25/11/11 at 04:41 PM Reply With Quote
Any reason you can't have an aluminium plate bonded to the front of the cutout?
[Edited on 25/11/11 by stevebubs]
