Author: Subject: It's starting!!!
Poorscousertommy
posted on 25/11/11 at 11:41 AM Reply With Quote
It's starting!!!
So After months of research and lurking on here, im off to MK tomorrow to place my order!!
Now, before I commit to a 2.0 duratec install, need some advice:
Which gearbox!! Type 9 or MT 75??
Which is the better box (change, ability to handle power, noise etc), and which is the easiest (and cheapest) to mate to a duratec??
Mark
graememk
posted on 25/11/11 at 11:48 AM Reply With Quote
type 9
mcerd1
posted on 25/11/11 at 12:01 PM Reply With Quote
you can get off the shelf bellhousings for the type 9 to fit loads of different engines (inc, Duratec) and there are loads of upgraded gearsets to pick from too
the MT75 is a little stronger as standard, but doesn't have a removable bellhousing or give you as many options on the gearsets
MkIndy7
posted on 25/11/11 at 12:40 PM Reply With Quote
2007 onwards MX5 box seen as they were designed for that engine and bolt straight up!.
(only possible problem is they canter the engine over meaning the off the shelf shallow sumps might not be totally suitable)
posted on 25/11/11 at 12:57 PM Reply With Quote
Mazda box bolts straight up.
I would like to suggest a Toyota W58....
big-vee-twin
posted on 25/11/11 at 02:58 PM Reply With Quote
I'm using a type 9 most people seem to use this, aparently ok upto about 200hp with standard Duratec at 150 ish.
You can get a Mazda MX5 Engine and Box - Same Engine as the Ford Duratec was designed by Mazda/Ford.
http://www.triangleltd.com
Johneturbo
posted on 25/11/11 at 03:50 PM Reply With Quote
That THING looks like it weighs more than my car
wilkingj
posted on 25/11/11 at 04:22 PM Reply With Quote
Talk to Rusty Nuts about type 9 boxes and the BHG(??) ratio kit. he recons well worth the investment, as they make the box more useable. Namely first gear is way to short or long for a kit car.
Not 100% sure of the exact details, but its deffo a T9 that he modified.
Me?? I'm a LT77 man with a V8 on the front of it, and my first gear is all wheelspin!
Mel knows his stuff on the T9 mods.
Hope this is of some use.
Best Regards
Geoff
http://www.v8viento.co.uk
jeffw
posted on 26/11/11 at 06:46 AM Reply With Quote
BGH not BHG
BGH Geartech
geordielad
posted on 26/11/11 at 08:08 AM Reply With Quote
will this bolt to a zetec?
