Daddylonglegs
posted on 26/11/11 at 07:48 AM |
O/T - Heating Oil
Morning all. I thought I'd ask the Oracle that is the LCB forum for some advice.
We are at present renting a house in a rural area running on domestic oil for heating etc. We filled the tank a couple of months ago anticipating
another big freeze, but we now have a dilema. We are hopefully moving to another property which is also oil-fired, the problem is, the place we are
moving to has an almost empty tank (they knew they were moving so ran it down), our move came a little out-of-the-blue so we are now stuck with an
almost full tank here and need to see if there is anyway we can shift the oil to the new property. At today's prices, a full tank is worth a
hell of a lot of cash!
Anyone on here had a similar experience, or have any good ideas? I doubt that selling the fuel to the landlord is an option (it's a long story),
so any help/advice gratefully received.
Thanks.
JB
franky
posted on 26/11/11 at 07:56 AM |
I've just done the same when moving house, I filled lots and lots of 25 and 50 ltr drums to do it. You can pay a company to do it too if you
want. Quite a common practice
Wheels244
posted on 26/11/11 at 08:27 AM |
I fitted a new tank as the old one was looking a big scabby when we bought the house.
I decanted the oil into 45 gallon drums using a little 12v pump which came off a caravan, dropped into the tank
With the hose attached and worked amazingly well. Took the old tank out, fitted the new one and reversed
The process.
It's easy enough to get the drums.
graememk
posted on 26/11/11 at 08:33 AM |
go down to local Taliban hand car wash and get some barrels from them.
Daddylonglegs
posted on 26/11/11 at 08:37 AM |
ROFL
big_wasa
posted on 26/11/11 at 09:07 AM |
Yes you can get it pumped across by the firm you use but its not cheap. But cheaper than giving it away.
How much is a full tank ? 1100 L takes a lot less moving than 2700 L.
Do you know any farmers ? They will have pumping gear and bowsers for moving fuel.
[Edited on 26/11/11 by big_wasa]
v8kid
posted on 26/11/11 at 10:06 AM |
Had a similar problem when I had to moove my tank. I pumped it into a couple of IBC available almost everywhere for a few quid. Used a tractor to lift
the IBC,s
Btw I add my used engine oil to the heating oil as a method of disposal also getting the heat out of it. No probs so far - any comments?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
rodgling
posted on 26/11/11 at 10:15 AM |
If it's worth X and it costs Y to move it, sell it to the buyers for X-Y (and maybe a little more discount for the hassle).
MakeEverything
posted on 26/11/11 at 10:22 AM |
Being a heavier oil it will make a mess of your burner and filters unless it's suitably mixed with the heating oil. From my limited exposure to
heating oils commercially and from memory, the oils are rated for time (15 seconds and 20 seconds etc) which is the viscosity to calculate the burn
time and flow rate, so adding too much will thicken it. I'm not too clued up on the subject of oils, but someone here might be able to
illuminate us further. Engine oil will make a mess of the fuel filters though.
Kindest Regards,
Richard.
fesycresy
posted on 26/11/11 at 10:28 AM |
Yes, it comes in 28 and 35 second.
A word of warning, I have used 'professional' companies to empty oil tanks that I have to relocate.
They can cause more problems than the worth, you end up with a lot more sh1t in the tank and can be plagued by blocked filters and nozzles for
literally years to come.
I would do it myself as said above.
ReMan
posted on 26/11/11 at 10:35 AM |
That was my thinking and ave a lot of hasell
www.plusnine.co.uk
Neville Jones
posted on 26/11/11 at 11:07 AM |
When ships and large motor yachts are sold, the bunker is sold as a separate item.
The new tenants are going to need heat, so they would be better off buying what is already there, and you take that cash and fill up where you move
to.
Maybe that's too simple a solution?
Nev.
bobinspain
posted on 26/11/11 at 01:10 PM |
Given the above and the fact that from your original comment, you intimate that the landlord is a bit sh77y, why not threaten to take the oil
away unless the landlord pays you for it. That way, if he doesn't cough up, you'll leave a load of crap at the bottom of his tank
an possible airlocks in the heating system which he'll have to foot the bill for unless he's willing to come to a muttual accommodation
with you.
mad4x4
posted on 26/11/11 at 04:42 PM |
Borrow a Trailer and get one of These, should be able to move 1000 liters in 1 hit. need a Pump
http://www.ebay.co.uk/sch/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A5800
&rt=nc&_nkw=ibc&_dmpt=UK_BOI_FarmingEquipment_RL&_trksid=p3286.c0.m14&_sop=7&_sc=1
Scot's do it better in Kilts.
posted on 26/11/11 at 04:49 PM |
If you have enough to fill an IBC you will have to borrow a hefty trailer to carry it.
