Author: Subject: Pedal Box - I am rubbish - Cannot make a decision !
wombat
posted on 27/11/11 at 06:52 PM Reply With Quote
Cannot make my mind up do I :-
1. OBP Pedal Box with balance bar
2. Tiger own set up
For and against:-
1. One piece of kit and looks good - But will it pass IVA Norwich
2. Proven set up which passes IVA Norwich - Clutch n Brake are seperate units and throttle is a top mount swing
Heart says OBP Type
Head says Tiger
Aaaaaarghh !
T66
posted on 27/11/11 at 06:58 PM Reply With Quote
Ive got an OBP box - why wont it pass an IVA ?
My car isnt IVA yet however...
Nash
posted on 27/11/11 at 07:10 PM Reply With Quote
Adjustable balance bar is not acceptable for IVA
Build It, Buy It, Drive It:
Southern Kit Car Club
wombat
posted on 27/11/11 at 07:13 PM Reply With Quote
T66
From searching the net, build blogs etc I picked up that certain IVA stations dont like bias bars. A friend of mine has just had a nightmare getting his Sebring through at Norwich recently. Ended up re-piping and fitting a mini cooper proportion valve.
I only want to do it the once ta.....
wombat
posted on 27/11/11 at 07:14 PM Reply With Quote
Nash
Even if drilled and pinned off ?
Nash
posted on 27/11/11 at 07:25 PM Reply With Quote
I believe the ruling is you can't Adjust them once set. I do seem to recall a lot of debate around the drill and pin question. May be worth checking with VOSA
Neil
T66
posted on 27/11/11 at 07:32 PM Reply With Quote
Good point - I had assumed that drilling & pin was acceptable, sure I had read somewhere of them getting a spot of weld on them.
Its all designed to put us off Im certain....
wombat
posted on 27/11/11 at 07:36 PM Reply With Quote
T66/Nash
Thx for feedback.
As you see its not quite as simpe as it sounds at first.
Sure some other knowledge to come from locosters yet.....
sdh2903
posted on 27/11/11 at 07:47 PM Reply With Quote
I have an OBP one, ive used lock nuts and its all wirelocked up, I'm sure at the time that was deemed acceptable but haven't been through IVA yet. Not sure if the goalposts have moved again tho?
Stuart_B
posted on 27/11/11 at 08:13 PM Reply With Quote
hi there, eddie99 recently passed his iva at Norwich, with a bias bar, i will point him to this thread and he can tell you what he done
stu
loggyboy
posted on 28/11/11 at 07:26 AM Reply With Quote
iirc, the latest iva manual confirms drilling and lock wire is acceptable.
loggyboy
posted on 28/11/11 at 07:33 AM Reply With Quote
to confirm, note 5 section 9b does state lockwire is acceptable.
iank
posted on 28/11/11 at 07:56 AM Reply With Quote
But you need a warning sticker telling the next owner not to remove the lockwire. 9b item 27 and note 6
Wording required is
"Adjusting front/rear brake bias may invalidate approval and breach Construction and Use requirements. "
IVA is easier in this respect than SVA. I think they realised everyone was just making them adjustable again after the test.
[Edited on 28/11/11 by iank]
Anonymous
wombat
posted on 28/11/11 at 11:42 AM Reply With Quote
StuartB,loggyboy,iank
Thx for the feedback.
Any advice on setting it up before locking off?
Thinking it would be a pain if tester says balance is incorrect at that stage...
Stuart_B
posted on 4/12/11 at 04:41 PM Reply With Quote
i helped eddie set up his, to pass the iva, have he had the most force as we could on the front and then wind back 4 turns, which woudl give you around a 70/30 spilt.
but we had an area where we tested it
hope this helps
stu
wombat
posted on 4/12/11 at 08:30 PM Reply With Quote
Cheers Stu, yup talked with Ed too.
Luckily we are fairly rural here so will be able to try it out before hand.
Thx
wombat
posted on 19/12/11 at 10:39 PM Reply With Quote
OBP Pedal Box
OK decision made and bought an OBP Pedal Box. Nice piece of kit, well finished.
Anyone got pictures of linking throttle and clutch cables to pedals with this box?
