thefreak
posted on 29/11/11 at 11:46 PM |
Pressing bushes out
So... how much should I expect to pay a garage to press a full set of bushes out of the wishbones when they're off the car?
I managed to bust the vice doing it myself tonight, so it's either get someone else to do them (and pay) or get hold of a hydraulic press. The 6
ton ones seem to be going for around £70 on ebay...
owelly
posted on 29/11/11 at 11:54 PM |
Make a press. Cheap bottle jack and £10s worth of RSJ, and a bit of welding.
Failing that, it depends what sort of garage you find. A big shiney garage will be £85/hour or a grubby garage will charge you a fiver for the tea
fund.
http://www.ppcmag.co.uk
thefreak
posted on 29/11/11 at 11:56 PM |
I might drop round a couple Thursday then. I'm trying to justify buying one, but I can only see it used for this purpose? Plus I've only
got 2 cars that need doing
Nickp
posted on 30/11/11 at 07:22 AM |
Set fire to them with a blow lamp. Not the 'greenest' method but works for me
thefreak
posted on 30/11/11 at 07:33 AM |
Did try that, ended up running out of gas
Nickp
posted on 30/11/11 at 07:50 AM |
Just concentrate on getting the metal as hot as poss, then that'll melt and set fire to the rubber.
snowy2
posted on 30/11/11 at 07:57 AM |
I have in the past drilled them out.
sometimes you are the pigeon, most of the time the statue.
designer
posted on 30/11/11 at 09:04 AM |
Drill all around the rubber bush to weaken it and then remove with drivers and such.
DixieTheKid
posted on 30/11/11 at 09:05 AM |
Yep burn them out, use a bit of threaded bar and some penny washers, tighten the nuts either side to press the new ones them back in.
COS IT'S Worth IT
Benzine
posted on 30/11/11 at 09:14 AM |
I like to drill a few holes and use fire, gives more surface area for the flames to attack and speeds things up. There are few things more
satisfying in life that seeing a burning bush plop to the ground out of a wishbone unaided.
T66
posted on 30/11/11 at 10:51 AM |
Persevere - with the heat & mell - should be easier with them off the car.
One set I did , cannot recall on what, I cut the rubber bush out once I had torched it, then put the blade of my hacksaw through the bush and sawed it
into two bits
Then took a No2 mell to it once split.
motorcycle_mayhem
posted on 30/11/11 at 10:54 AM |
Errr.... if you fancy a trip down to Cornwall...... I'll press them out just for a chat over a pint....
Autosri
posted on 30/11/11 at 11:44 AM |
I normally remove them with a bit of threaded rod and a couple of sockets one just smaller than the ID of the wishbone and one just bigger and pull
the bush into the bigger socket normally works for me
posted on 30/11/11 at 12:20 PM |
Concentrate the heat on the metal side of the bond between rubber and metal, after that hacksaw and peel back the annular metal part with a cold
chisel.
zilspeed
posted on 30/11/11 at 01:11 PM |
chisel.
What he said - especially the second bit.
Hacksaw a split in the outer sleeve.
Fold it in on itself with a chisel.
It falls out at that point.
Threaded road, nuts, washers, etc to pull the new ones in.
posted on 30/11/11 at 01:49 PM |
chisel.
I have a good selection of old large sockets in Metric, AF and Whitworth sizes that are very useful for pressing bushes and bearings in with.
I've picked them up for pennies at car boot sales.
