matty h
posted on 30/11/11 at 09:24 PM |
windows xp install
Can any computer buffs help me out.My hp pavilion desktop computer crashed.I have a window xp disc and coa but when trying to install it says unable
to find hard drive.
Please could anyone give me some assistance.
Thanks Matty
T66
posted on 30/11/11 at 09:32 PM |
Are you restarting the PC with the disc in the cd drive, I recall it needs to boot from the cd.
If you press F8 when its booting, you can get into the dos settings and force it to boot from the cd.
bleepingcomputer.com is your friend
McLannahan
posted on 30/11/11 at 09:33 PM |
When you turn on your computer it goes through some basic checks. The BIOS is the detection and recognition of the hardware (inputs and outputs). If
BIOS doesn't detect your hard drive (excluding some server hard drives which can run on an extra BIOS and controller) then Windows won't
either.
Switch on your PC. Press F1 when the HP logo comes up. This will take you into BIOS. See if BIOS will detect/see your hard drive.
graememk
posted on 30/11/11 at 09:37 PM |
at a guess its a sata hard drive, you might need some extra drivers when you install windows
matty h
posted on 30/11/11 at 09:43 PM |
Have looked in the BIOS and it sees the hard drive,where would I get the driver from or find out if I have a SATA hard driver.
Thanks Matty
McLannahan
posted on 30/11/11 at 10:03 PM |
Good news that BIOS sees it. It should give the model number and that'll tell us if it's a SATA drive or not. Do you know the model number
of the Pavillion?
matty h
posted on 30/11/11 at 10:08 PM |
Product number is A808.uk
Thanks Matty
McLannahan
posted on 30/11/11 at 10:13 PM |
Damn....Your model can have either SATA or PATA!
http://h10032.www1.hp.com/ctg/Manual/c00253983.pdf
What does BIOS detect the drive as Matty?
posted on 30/11/11 at 10:19 PM |
Open the case and look at the cable IDE has a very wide cable
3 main types of hard drive IDE, SATA and foobared .
MikeFellows
posted on 1/12/11 at 01:21 AM |
firstly does your windows xp disk have service pack 3 included, if it doesnt your fighting a losing battle - go get a updated disk
if it doesnt work then...
go into your bios and see if the hard disk controller is set to AHCI if it is change it to SATA or IDE
try windows again
if this doesnt work, set it back to AHCI (will give a performance boost) and you need to find out the make and model of your motherboard - it should
be printed on it and download the drivers for your controller (or post in here and I will help you find them)
then you have 2 choices
1. copy the files you downloaded to a FLOPPY disk (yes a floppy disk - its the only thing xp will read from) and press F6 at the start of setup to
install the additional drivers
2. add the files to a windows xp ISO and burn back to disk - a lot more complicated than you would think it should be - there is a program called
nlite that will help you do this
hope that helps
jossey
posted on 1/12/11 at 09:18 AM |
take it to the "experts" at pcworld. then when they break it send it to me lol
David Johnson
loggyboy
posted on 1/12/11 at 09:27 AM |
Maybe it crashed because your HDD is broken? Hence why it wont reinstall?
graememk
posted on 1/12/11 at 12:02 PM |
your welcome to bring it over to me in sutterton and i'll sort it for you for a beer or 4
matty h
posted on 5/12/11 at 10:46 PM |
Thanks for your help,I have now had chance to take another look and found the following details
Hard drive PM-SAMSUNG SP0802N
BIOS Version P4VM900-SATA2 BIOS P1.10
Will I need to find a hard drive driver ?
Thanks Matty
MikeFellows
posted on 5/12/11 at 10:48 PM |
you need to motherboard model / make
its not a hard disk driver you need, its a hard disk controller driver and thats on the motherboard
matty h
posted on 5/12/11 at 10:57 PM |
Is this
the motherboard details or do I need to look on the motherboard itself.
Sorry for the questions but I am a computer numpty.
Thanks Matty
MikeFellows
posted on 6/12/11 at 12:36 AM |
have a look on the motherboard for a printed brand / model number - take note of any revisions too - many manufacturers release many revisions of
boards
Furyous
posted on 6/12/11 at 05:57 AM |
What makes you think you need to reinstall? If it's a hardware fault, reinstalling won't fix anything. If it's software,
there's a good chance you (or someone else) could fix it without reinstalling.
"Crashed" is a very vague term. What exactly is it doing?
matty h
posted on 7/12/11 at 06:35 PM |
Message that come up when switched on is
Windows could not start because the following file is missing corrupt
Windows root >\system32\ntoskrnl.exe.
Please re-install a copy of the above file.
Does anyone have any suggestions.
Thanks Matty
Furyous
posted on 8/12/11 at 05:22 AM |
Try following this video:
http://www.youtube.com/watch?v=j69K9H87j2s
It shows you how to reinstall the ntoskrnl.exe file. It seems simple enough to me, but that could be because I understand it anyway. As long as you
follow it step by step, it shouldn't be too difficult.
mcerd1
posted on 8/12/11 at 08:13 AM |
I've had a problem like that maybe 3 or 4 times now - every time it was caused by a dying hard disk
not saying its definatly that, but if its an older drive and you've not got a virus then its the likley cause of your problem
