PAULD
posted on 2/12/11 at 03:33 PM |
Day off.
Took the day off today to change my daughters Focus cambelt (04 reg). Removed crankshaft pulley cover and the pulley was nothing like the others I,d
done, no holes to lock it or pull it off by, just an extra unused pulley. Went and bought a later Haynes book, just the same as my old one, no mention
of this pulley type. Question is how do I lock the pulley to undo it and how do I hold it to torque it back up? Answers on a postcard
please............
mrwibble
posted on 2/12/11 at 03:44 PM |
mk1 or mk2, zetec se or e or duratec
[Edited on 2/12/11 by mrwibble]
Which engine is it?
Do you have to undo a big bolt in the middle, or are there multiple smaller fasteners that bolt the auxiliary pulley to the timing belt pulley?
A big impact gun is the easy answer, you often don't need to lock the crank at all with one of these. Otherwise removing the starter and using
a pry bar in the ring gear teeth might be possible.
PAULD
posted on 2/12/11 at 03:55 PM |
day off
Thanks for the replies. It's a facelift mk1 with the zetec se (I think). Centre bolt fixing.
mistergrumpy
posted on 2/12/11 at 04:19 PM |
I know nothing other than having read various belt change routines. I'm not brave enough to do them having made a pigs ear of one once but there
wouldn't happen to be a way of holding the crank behind the pulley would there? Like flats filed in or summat?
PAULD
posted on 2/12/11 at 05:16 PM |
No holes, no flats, nothing.
Marcus
posted on 2/12/11 at 07:17 PM |
If its anything like Alfas, you will probably need a set of camshaft locking blocks to stop everything moving.
You take off a cam bearing retainer and fit to the same studs. it has the shape of the cam machined into itand stops it moving...
Spotted this on the bay of E:
DRAPER 61262 ZETEC SE CAM SHAFT SETTING & LOCKING KIT | eBay
[Edited on 2/12/11 by Marcus]
Marcus
Because kits are for girls!!
jacko
posted on 2/12/11 at 07:24 PM |
Someone i know tried to do a cam belt for a lady friend and bent all the valves
He said its the last time he is going to help others
It cost him a fortune to put right
ps it was a Focus too
Jacko
[Edited on 2/12/11 by jacko]
posted on 2/12/11 at 08:09 PM |
What size engine ? What year is the car? Some of the later ones don't have a tensioner on the auxiliary belt just a stretch belt which
isn't supposed to be refitted without special tools. To time the engine when removing the timing belt you will probably need a couple of special
tools , one which fits in the end of the cams away from the belt end which is a straight bar and another that screws into the block after removing a
plug from just above the O/S drive shaft to locate the crank . The cam sprockets need to be slackened off , DO NOT use the cam timing tool to hold the
cams when doing this !!! Use a sprocket holding tool
theconrodkid
posted on 2/12/11 at 08:39 PM |
you need an impact gun to get the pulley off,the crank gear is held on my the pulley bolt being tight,turning the engine with the bolt loose will bend
your valves.
who cares who wins
pass the pork pies
