Author: Subject: Stupid question about Rear brake Calipers
novacaine
posted on 12/12/11 at 06:13 PM Reply With Quote
Hi All,
I am in the process of changing rear pads on a 57 reg Fiat Bravo
I cant for the life of me get the rear piston to retract
I have one of the retraction tools
If i turn the piston clockwise as you look at it, the piston comes out (i.e the wrong way) but trying to turn it anticlockwise its rock solid and wont budge
Where am i being stupid? what am i doing wrong?
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
rodgling
posted on 12/12/11 at 06:32 PM Reply With Quote
Loosen the bleed nipple?
Stott
posted on 12/12/11 at 06:52 PM Reply With Quote
Sounds dull but is the handbrake on?
adrianreeve
posted on 12/12/11 at 07:09 PM Reply With Quote
You need to apply some downwards pressure as you turn (apologies if I'm teaching egg sucking here!). I find a g clamp gradually tightened as you turn the piston always works with rear callipers
Adrian
posted on 12/12/11 at 07:42 PM Reply With Quote
Slacken off handbrake cable tensioner, then take lid off fluid reservoir, then screw and push the piston.
Ideally especially on cars with ABS rather than taking the lid off the reservoir it is better to clamp the flex hose and open the the bleed nipple.
[Edited on 12/12/11 by britishtrident]
posted on 12/12/11 at 07:58 PM Reply With Quote
On some modern rear calipers you have to use a left handed threaded tool,It may be possible to wind the piston backwards while turning the outer section of the tool to apply pressure? On others with an electric parking brake you need a tool to plug into the DLC
jabs
posted on 13/12/11 at 08:06 AM Reply With Quote
Found this on the Fiat forum - would explain the problem
"Basically it started when me & my mate decided to change the Discs & Pads on my 2007 Fiat Bravo 1.4 Tjet. Having never owned or worked on an Italian car before we weren’t aware that Fiat Bravo’s (and Stilo’s) have opposite hand threads when winding in the rear calipers, as every car we’d both worked on (and seemingly ever produced) has Right hand thread calipers on both sides. "
novacaine
posted on 14/12/11 at 01:17 PM Reply With Quote
Thanks to all for replies, can always rely on this forum for answers to any car related question, Cheers!
I'm having a crack at it tonight, the tool i have only goes clockwise so i think some jiggery pokery is required
Matt
Ninehigh
posted on 14/12/11 at 02:14 PM Reply With Quote
When I looked into getting a wind back tool I was told there was a left and right one, different thread because either side goes in in different rotations
