Author: Subject: best glue
jabbahutt
posted on 20/12/11 at 02:03 PM Reply With Quote
best glue
Hi all
Actually managed to get some time in the garage this week only to find one of the glass from a wing mirror had fallen out. What in your collective opion would be the best adhesive readily available from Halford/B&Q etc to reattach it into the wing mirror?
It looks like there are 3/4 studs with large blobs of rubbery adhesive where it was attached.
Any input welcome as it would be nice to put the car to bed over the winter with all the relevant pieces attached.
jossey
posted on 20/12/11 at 02:19 PM Reply With Quote
2 part epoxy but needs to be dry ish to dry properly.
David Johnson
liam.mccaffrey
posted on 20/12/11 at 02:31 PM Reply With Quote
I'd go PU everytime
Build Blog
Build Photo Album
hootsno1
posted on 20/12/11 at 03:17 PM Reply With Quote
It's got to be q bond
If a little hammer won't fix it get a bigger hammer
tomgregory2000
posted on 20/12/11 at 03:35 PM Reply With Quote
sikaflex
jabbahutt
posted on 20/12/11 at 04:09 PM Reply With Quote
thanks for the replies, I thought sikalfex to start with but as it is only in 300ml cartridge discounted it. Unless anyone knows of similar adhesive to sikaflex available in smaller tubes?
tomgregory2000
posted on 20/12/11 at 05:33 PM Reply With Quote
sikaflex comes in 100ml as well
jacko
posted on 20/12/11 at 05:39 PM Reply With Quote
If the glue is going to touch the mirror don't use pu type glues IE sikaflex / tiger sealer / etc etc it will show though the mirror after a few days
Jacko
mark chandler
posted on 20/12/11 at 05:40 PM Reply With Quote
Quick dry two pack araldite, it will be solid in 15 minutes and bullet proof the next day
designer
posted on 20/12/11 at 07:03 PM Reply With Quote
Quick dry araldite, don't use superglue like so have done.
Neville Jones
posted on 20/12/11 at 07:55 PM Reply With Quote
Jacko
Hasn't done on my Transit bus mirrors, been glued on with PU all that time and no probs. I'd use PU every time. The bonus is that it has a bit of 'give', flexibility, so less chance of cracking in a bump.
Nev.
