Author: Subject: fuel tank mounting?????
webbey
posted on 20/12/11 at 10:40 PM Reply With Quote
Hi there
I have made a fuel tank and now I need to fix it in my car, I was thinking of using some rubber mounts to go from the frame to angle iron brackets welded to the base of my tank but I have seen allot of straps, in your opinion should I use the rubber mounts, bolt the tank straight to the frame, or use some type of straps???? Help please
Ben_Copeland
posted on 20/12/11 at 10:50 PM Reply With Quote
I used ally straps with foam tape between straps and tank, plus foam tape under the tank where it sits on the chassis.
Traps bolted to chassis.
Ben
Locost Map on Google Maps
Enter Your Details Here
craig1410
posted on 20/12/11 at 11:50 PM Reply With Quote
+1 nice and easy this way
Simon
posted on 21/12/11 at 12:04 AM Reply With Quote
I used some steel straps, with car floor rubber between.
You need to be able to tighten strap down so one end can be screwed to chassis, the other will need to be able to be tightened to pull tank down. Iirc rubber is a "requirement". I folded the strap over a bit of bar, which I drilled and tapped, then drilled a hole in the strap, so I could get a bit of studding into, then bolt this down through a chassis fixture.
Simon
Bluemoon
posted on 21/12/11 at 03:31 PM Reply With Quote
It's more than a "requirement" if you don;t want the tank to ware though as the tank moves about you should use rubber.. Metal to Metal contact is a no-no. Also weld on lugs are not a good idea either unless you sit the whole lot on a rubber isolating mounting..
Dan
