SALAD
posted on 23/12/11 at 09:02 PM |
Brake Options...
My brain is starting to melt after trawling through the search results so are the following discs and pads suitable for my car?
The fronts are Sierra hubs and calipers from a 2.0l Pinto'd car and the rears are from an XR4x4 (can't remember if it was a 2.8 or
2.9).
eBay - The UK's Online Marketplace
Aceparts Performance Lighting
If those discs are crap then do say.
Ben_Copeland
posted on 23/12/11 at 09:34 PM |
Buy some wilwood powerlites instead
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
SALAD
posted on 23/12/11 at 09:37 PM |
NO Ben! The Sierra calipers are shiney refurbs and the extra money is needed elsewhere......like for a rollcage, wheels, seats etc
robocog
posted on 23/12/11 at 09:41 PM |
I used KA solid callipers and early sirerra pov spec solid disks along with some Mintex sooper dooper pads
Changed the master cyl for a Fiat Panda item and well happy with the setup
(much better bite and feel than when I had the Sierra master cyl and the vented setup)
Didn't compare weights but I guess its also a far bit lighter with my new setup
Regards
Rob
SALAD
posted on 23/12/11 at 09:52 PM |
Hello Rob, hope you're all good.
I might change my master cylinder so a Panda one could be good....?
I'm going to keep everything else I have at the moment just need disks and pads.
robocog
posted on 23/12/11 at 10:20 PM |
Pads....I should have some EBC Greenstuff pads for the vented Sierra callipers here somewhere if you want to keep the costs way down - will try and
dig them out if you want them and bring them to the next Cadnam meet?
(unless you are going to Wickham square on Boxing Day??)
I changed them in the hopes it would improve the bite a bit- really cannot recall if it made much difference TBH- didn't do many miles on them
before ditching the venteds and fitting the new master cyl
I /should/ also have the vented disks... somewhere
I read good things about the Mintex M1144 pads so went with them with the new setup and will replace them with the same when they finally need doing
(if that actually occurs in my lifetime) - they have a good bite and not yet eaten the disks alive or given me any scary moments - seem to work good
from cold and not had them fade* (*dsclaimer I drive like a grandad and not got the bottle nor the money to do a track day)
Will try and find what master cyl I used was - I know it was a cheapy brand new item from eBay and was for a Fiat Panda without a servo - only knock
on effect was it required a remote reservoir - again I sourced one from eBay from a Daihatsu Hijet for very little in the way of cost - I /may/ have
had to change the brake fittings as well - I know I had to remake at least one line as I also ditched my front to rear bias Fiat doohickey that had
developed a leak - turns out /my/ car doesn't need one and the fronts lock before the rear anyway without it
Don't know what bits made the biggest improvement - all I can say as a package it fulfilled what I had aimed to achieve at very little cost
If you want to get new pads - I would go with the Mintex M1144's and skip the EBC Greenstuff's TBH
(My offer still stands though!)
Regards
Rob
robocog
posted on 23/12/11 at 10:28 PM |
The master cyl I went with.....
BENDIX 132233B
19.05mm
BRAKE MASTER CYLINDER
SUITABLE REPLACEMENT FOR
FIAT PART No 793010
SUITABLE FOR THE FOLLOWING FIAT VEHICLES
WITH BENDIX BRAKES
LEFT HAND DRIVE (UNLESS STATED)
FIAT VEHICLES
SEE DISCRIPTION & CHECK PHOTO & PART NUMBER
AGAINST YOUR MODEL
FIAT PANDA 1000 From Chassis No 6261412
JAN 1985 -- DEC 1992
FIAT PANDA 1000 i.e From Chassis No 6261412
OCT 1987 -- JAN 1993
FIAT PANDA 1100 From Chassis No 6261412
JAN 1993 -- JAN 1995
FIAT PANDA 750 From Chassis No 6223908
JAN 1986 -- JAN 1991
FIAT PANDA VAN 1000 From Chassis No 6261412
JAN 1986 -- FEB 1992
FIAT UNO 1.3 Super Diesel From Chassis No 0038873
LEFT & RIGHT HAND DRIVE VEHICLES
JUNE 1983 -- JAN 1985
FIAT UNO 45 0.9 From Chassis No 0723819
MAR 1983 -- JAN 1989
FIAT UNO 45 1.0 From Chassis No 0723819
JUNE 1986 -- JAN 1989
FIAT UNO 45 i.e 1.0 From Chassis No 0723819
APR 1984 -- JAN 1989
FIAT UNO 55 1.1 From Chassis No 1570529 / 0324161
JAN 1983 -- JAN 1989
Regards
Rob
SALAD
posted on 28/12/11 at 10:04 PM |
Thanks for that Rob, very useful, I will source a few bits on line. Master cylinder change for sure but I will decline the vented disks and pads
though as I am planning on going with solids.
Those discs in my 'bay links will be ok won't they?
SALAD
posted on 30/12/11 at 12:35 AM |
Am I correct in thinking that as I have standard 2.0l sierra front calipers and xr4x4 on the rear, the disc sizes available will always end up bigger
on the rear??.......thus a proportioning valve is needed.....maybe.
Also how do I know if my calipers are for solid or vented discs.....or does it not matter?
