Author: Subject: Help with tin top no reving
jacko
posted on 28/12/11 at 09:41 PM Reply With Quote
Hi all
I have a Vectra c sri dti 150 diesel and when driving it today it stopped reving for a few seconds then started to work ok agane
has anyone come across this before if so what is the cure
thankyou
jacko
iank
posted on 28/12/11 at 10:02 PM Reply With Quote
Sounds like it went briefly into limp-home mode. Usually an unexpected sensor value, so might never happen again or conversely get worse/more frequent.
If you can read out engine codes from the ECU then it might have an error code that will give a hint.
Can be tricky to find, but this thread shows how things can go http://www.vectra-c.com/forum/showthread.php?t=101741
Anonymous
Madinventions
posted on 28/12/11 at 11:03 PM Reply With Quote
Check you number 3 injector plug for corrosion. Also do a quick google search for 'collapsed vacuum hose' problem.
I've had both of these with the same sort of symptoms, but they're both really easy fixes.
Ed.
View my band website:
http://www.shadowlight.org.uk
graememk
posted on 29/12/11 at 12:47 AM Reply With Quote
has it ever had a new "EGR" ?
jacko
posted on 29/12/11 at 09:30 AM Reply With Quote
Hi all
It has had a number 3 injector plug
No it has not had a EGR valve , i was thinking of going for some gaskets and cleaning the valve today
I will have a good look for split pipes [ any tips best to look ie turbo pipes
Please keep the info coming
PS the car has only 34000mils on the clock
Graham
[Edited on 29/12/11 by jacko]
Madinventions
posted on 29/12/11 at 11:33 AM Reply With Quote
If it's the 1.9 CDTi then this page will tell you pretty much everything you need to know
http://www.vectra-c.com/forum/showthread.php?t=130008
