<<  1    2  >>
Author: Subject: 50,50 petrol diesel mix
madteg
posted on 29/12/11 at 12:09 AM Reply With Quote
What can i do with 75lts of petrol diesel mix that took out of my sons car.
redscamp
posted on 29/12/11 at 12:21 AM Reply With Quote
put it diesel car at a ratio of 15% to fight fuel waxing.
Dont try thickening it with engine oil.
Ben_Copeland
posted on 29/12/11 at 12:31 AM Reply With Quote
Not recommended in new diesels !
Ben
Locost Map on Google Maps
Enter Your Details Here
James
posted on 29/12/11 at 12:41 AM Reply With Quote
Use some of it for cleaning greasy car parts maybe?
James
Rocket_Rabbit
posted on 29/12/11 at 01:24 AM Reply With Quote
Centrifugally separate it?
Yazza54
posted on 29/12/11 at 02:03 AM Reply With Quote
Drink it
I'm unhappy cos I eat and I eat cos I'm unhappy
hobbsy
posted on 29/12/11 at 03:37 AM Reply With Quote
If you've got an old indirect injection diesel like an old Merc or Peugeot or an non-PD VW TDI you may be able to use it as transport fuel.
Otherwise use it to burn stuff!
morcus
posted on 29/12/11 at 04:11 AM Reply With Quote
Thicken it and write on stuff with it then light it in the dark.
HowardB
posted on 29/12/11 at 08:02 AM Reply With Quote
sell it to a man that has oil fired central heating, 75litres in a 500+litre mix will make no odds,...
Howard
Davegtst
posted on 29/12/11 at 08:49 AM Reply With Quote
Doesn't work i'm afraid, otherwise i would be an extremly rich man. Apparently you can separate it by heating it. I've never tried but i guess you have to be pretty brave to do it. Don't put it in a car either you could cause alot of damage to the pump and injectors. It's great for cleaning greasy parts though.
Mal
posted on 29/12/11 at 08:58 AM Reply With Quote
Take it to your local tip and put it in the waste oil tank.
jollygreengiant
posted on 29/12/11 at 09:11 AM Reply With Quote
Use it in an old Orchard Heater. It works a treat for keeping a LARGE garage workshop warm in winter.
matt_gsxr
posted on 29/12/11 at 09:54 AM Reply With Quote
Shouldn't it be possible to reclaim the duty that was paid on this. The duty was based on it being used as vehicle fuel (which is now can't).
I bet the big oil companies get away with this, but probably more difficult for the individual.
http://customs.hmrc.gov.uk/channelsPortalWebApp/channelsPortalWebApp.portal?_nfpb=true&_pageLabel=pageVAT_ShowContent&id=HMCE_CL_000510&pr opertyType=document
tonym
posted on 29/12/11 at 10:00 AM Reply With Quote
I would be very wary of using it for anything especially heaters or central heating. Petrol vapours will still explode even when mixed with diesel or even water all it needs is air. The only safe use would be to put it in an older non common rail diesel mixed 1gall to ten of diesel (5%)
[Edited on 29/12/11 by tonym]
JohnN
posted on 29/12/11 at 10:04 AM Reply With Quote
Bonfire Juice
zilspeed
posted on 29/12/11 at 10:15 AM Reply With Quote
I'd be dribbling that in, a gallon at a time into an older diesel.
Ninehigh
posted on 29/12/11 at 12:16 PM Reply With Quote
You could also put it in small quantities into an older petrol too, makes it smoke a lot but like I say small quantities
gaz_gaz
posted on 29/12/11 at 12:26 PM Reply With Quote
I managed to put 11 litres of petrol in my 58plate tdi a4 last night.
Brimmed it with 54 litres of diesel and hoping for the best
steve m
posted on 29/12/11 at 12:44 PM Reply With Quote
Not sure about in a 58 plate TDI
sounds very dodgy to me, but if you were to keep the tank brimmed with diesel over the next few hundred miles, it would dilute the mixture
If it was my car, i would of had all the fuel sucked out
hobbsy
posted on 29/12/11 at 01:17 PM Reply With Quote
Hmm ditto. 10:1 I would worry less about but 5:1 is quite a lot of petrol for a modern high pressure TDI
Simon
posted on 29/12/11 at 02:12 PM Reply With Quote
Leaf blower, fuel pump, vaporiser and pilot light
Simon
RoadkillUK
posted on 29/12/11 at 03:50 PM Reply With Quote
I'd put the barrel in a stolen car with some kind of detonation device and ...... sorry wrong forum
Just kidding MI5
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Dave Ashurst
posted on 29/12/11 at 05:09 PM Reply With Quote
I eventually used up all my waste diesel by adding to my petrol tank in small doses..... http://www.locostbuilders.co.uk/viewthread.php?tid=136997
Not sure how it would affect a lambda sensor, but my car's on carburettors and a dash of diesel improves performance.
Ninehigh
posted on 29/12/11 at 08:27 PM Reply With Quote
That costs a couple hundred quid (ask me how I know) so to be honest I'd go with keeping the tank full for the next 6 months, or in the case of the OP, maybe 1 litre of the mix per tankful
iank
posted on 29/12/11 at 09:18 PM Reply With Quote
Couple of hundred quid in fuel vs 5-10 times that for a new high pressure fuel pump if it all goes pear shaped.
Modern diesel fuel pumps really don't like petrol at all.
Anonymous
<<  1    2  >>
