Author: Subject: Windscreen Challenge
Dave Bailey
posted on 1/1/12 at 04:38 PM Reply With Quote
All,
Just looking for some inspiration....
The profile of the bottom of my screen does not match the profile of the scuttle.... I have been looking for rubber mouldings for ages but found nothing.... I am sure people have had the same problem... any pictures of your solution?
Dave B
designer
posted on 1/1/12 at 04:59 PM Reply With Quote
CBS do some deep inch deep U-channel that could possibly do.
http://www.nfauto.co.uk/download/trim_page.pdf
stevegough
posted on 1/1/12 at 07:36 PM Reply With Quote
My windscreen was made by robin hood, it has a slot in the bottom into which you thread the large rubber flap which fills the gap between it and the scuttle.
I'll have a look on robin hood's site to see if I can find you a pic of the profile.
In the meantime, this is mine....
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stevegough
posted on 1/1/12 at 07:43 PM Reply With Quote
Kit spares (robin hood's parts division) mention it here
but unfortunately, there's no pic of the 'T' seal. I'll keep looking for you.
It is something like this one
(This is a PDF file) you need adobe thingy to view it.
[Edited on 1/1/12 by stevegough]
Luego Locost C20XE.
Proby
posted on 1/1/12 at 07:48 PM Reply With Quote
My F27 has a very neat bead of black silicone. Looks neat and tidy.
posted on 1/1/12 at 08:05 PM Reply With Quote
If your screen was supplied by Luego there is a very good chance it was supplied to them by Lolocost/GBS so the sealing strip shown by Steve should do the job
Dave Bailey
posted on 1/1/12 at 08:54 PM Reply With Quote
I didn't get my screen from Luego however I think it is one that has been used on a Luego before.... I am sure that the car I saw this screen on had the gap filled with PU... Not sure I am happy doing this though.... I think the Delta link may have given me a profile I may be able to use....
thanks
Dave B.
Chippy
posted on 1/1/12 at 10:38 PM Reply With Quote
What I did with mine was to get a length of tadpole beading, (like used on the rear arches), and slid it under the screen secured with bit of silicone just to hold it in place. Had a look for a picture but none I'm afraid. HTH Ray
philhoward
posted on 2/1/12 at 08:31 AM Reply With Quote
Try Seals + Direct as they have hundreds of different rubber profiles.
Michael
posted on 2/1/12 at 04:54 PM Reply With Quote
I am looking for the same rubber seals, and decided to look at the C****hams.
This is what I found. http://www.caterhamparts.co.uk/product.php?id_product=2553
stevegough
posted on 2/1/12 at 05:24 PM Reply With Quote
Spot on - that's the stuff - you could buy the whole HEATED windscreen from them for a mere £414 !! that's gonna eat a long way into your "£250" budget for the whole car
Having said that, their photo shows how the rubber gasket fills the mismatched scuttle / screen profile : enlarge me
Luego Locost C20XE.
Michael
posted on 2/1/12 at 10:06 PM Reply With Quote
I am guessing a meter is all you need? I have not been in the garage for a while now and the fame is in the loft, so will measure before I stick my order in.
stevegough
posted on 2/1/12 at 11:17 PM Reply With Quote
The website says 'usually 2m per car' but you might get away with 1 metre - measure it (twice) !
Luego Locost C20XE.
Michael
posted on 7/1/12 at 08:11 PM Reply With Quote
Talking about fitting windscreen. I remembered today I need to get some of that tubing for the wiper motor, and the nut that holds the tube to the motor.
Where is the best, and reasonably place to get it?
Thanks.
posted on 8/1/12 at 09:47 AM Reply With Quote
Thanks.
S.V.C. or a breakers
Michael
posted on 8/1/12 at 04:36 PM Reply With Quote
Thanks.
Will try SVC then.
[Edited on 8/1/12 by Michael]
stevebubs
posted on 8/1/12 at 04:48 PM Reply With Quote
http://www.woolies-trim.co.uk/p-1797-rubber-extrusion.aspx
stevebubs
posted on 8/1/12 at 05:41 PM Reply With Quote
Thanks.
Minispares.com - search for wiper tube
