New Topic New Reply
Author: Subject: What is stonger 8.8 or 10.8 bolts?
steve m
posted on 3/1/12 at 02:08 PM Reply With Quote
Hi
I am changing all the bolts etc on the front suspension, and have both 8.8 and 10.8 bolts to choose from (8mm thread)
What if either would be the stronger?
Ben_Copeland
posted on 3/1/12 at 02:12 PM Reply With Quote
I always thought higher the number stronger it was....
Although 8.8 is plenty
[Edited on 3/1/12 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
Myke 2463
posted on 3/1/12 at 02:13 PM Reply With Quote
10.8
Be Lucky Mike.
rost
posted on 3/1/12 at 02:22 PM Reply With Quote
Are you sure you've got 10.8 grade bolts? The standard is for 10.9.
IIRC 10.9 grade bolts have a tensile strength that is around 200N/mm^2 higher than the 8.8 ones and they're a fair bit harder.
Grade 8.8 bolts should be fine with their 600N/mm^2
[Edited on 3/1/12 by rost]
Charlie don't surf!
steve m
posted on 3/1/12 at 02:30 PM Reply With Quote
Rost
you are right, they are 10.9 bolts, and i have enough to do all the jobs both sides with out mixing things up,
So if 10.9 is much stronger than 8.8, i will use the 10.9s
thanks guys
samjc
posted on 3/1/12 at 02:43 PM Reply With Quote
Ive been told 8.8 are ample as the higher the number the stringer they are but more strength means they are brital under vibration so could crack or so in told as ill be using 8.8 is their no sec in the iva regs.
pekwah1
posted on 3/1/12 at 03:02 PM Reply With Quote
damn you and your garage steve!!!!
just went out to work on the car as it was sunny, 10 minutes later i'm getting peed down on!!!!
StrikerChris
posted on 3/1/12 at 03:51 PM Reply With Quote
I've seen more snapped 10.9 bolts in work(heavy industry) than 8.8 They tend to snap like carrots rather than stretch or bend like 8.8's. That said if you've hit something hard enough in your car to snap one,the bolt would be the least of your worries!
Irony
posted on 3/1/12 at 05:22 PM Reply With Quote
From what I have read/heard I have ASSUMED that 8.8 will be okay for my suspension bolts. There is a post on here where a guy says you could swing a entire car from a single m12 8.8 bolt.
mad4x4
posted on 3/1/12 at 05:40 PM Reply With Quote
Yeah 8.8 are good enough for suspension just make sure they are stamped bolts so MR IVA can verify there strength.
Scot's do it better in Kilts.
posted on 3/1/12 at 06:28 PM Reply With Quote
A single M6 8.8 bolt could support the weight of a smallish car (~1.3 tonnes). An M12 bolt could support several cars; it would take about 5 1/2 tonnes to reach it's yield strength in tension.
mcerd1
posted on 3/1/12 at 07:01 PM Reply With Quote
^^ that's spot on
the first part of the number is its tensile strength , but the second part is how brittle they are (the higher the number the more brittle / less tough)
but I wouldn't worry about the 10.9's - I know most of the bolts on the sierra's are 10.9's
steve m
posted on 3/1/12 at 07:10 PM Reply With Quote
"Yeah 8.8 are good enough for suspension just make sure they are stamped bolts so MR IVA can verify there strength. "
that bit does not concern me, as been on the road 12 years
But all the other info is very usefull
rost
posted on 3/1/12 at 09:29 PM Reply With Quote
Small Example:
8.8 bolts have a maximum tensile strenght of about 800n/mm^2, lets say shear strenght would be around 90% of that:
For a single M12 bolt: (((pi*12mm^2)/4)*(800n/mm^2*.9))/9.81m/s^2=8297Kg that can be suspended from a single bolt.
Charlie don't surf!
Simon
posted on 3/1/12 at 10:38 PM Reply With Quote
Originally posted by rost
Small Example:
In other words, a bus
Simon
New Topic New Reply
