001Ben
posted on 3/1/12 at 04:16 PM |
Imp Engine Bike Carbs
Hi all just wondering if you would be able to help me out with a little project Im doing. Its a turboed imp engine which I have decided due to space
limitations that I want to use a set of bike carbs (not Injection TB’s) as my old metro SU carb will no longer fit.
If possible could someone recommend a certain type/make/model of carb which will work with pressurised air, between 10-15psi? Ive been looking around
the internet and have found information, in the end confusing me more and more!
Are there any carbs out there considered to be smaller than others in depth, physical size? (not choke etc) As I need to consider the shape and size
of the required plenum chamber that I can fit in.
Due to engine size and normal choke size I think a set of 600cc bike carbs will be best suited to the engine, can anyone confirm this too??
Many thanks in advance
posted on 3/1/12 at 07:18 PM |
Unless the engine has a Wills rings conversion and a block reinforcing plate I would forget supercharging an Imp engine, even then I would advise
against it.
Strontium Dog
posted on 3/1/12 at 07:25 PM |
When Janspeed fitted a turbo to the Metro they used a SU but stuck it to the side of the engine over the clutch housing as there was not much room in
the bay and a pipe to the manifold.
If you do use bike carbs then some off a 600cc bike should be about right but will be a lot harder to set up than one single SU. Also, with over a bar
of boost you will, I would have thought, need supporting mods to your engine. I know very little about Imp engines but I would suspect the bottom end
might need strengthening and I would think it would need a multi plate steel head gasket etc to stand a chance of hanging in there!
Cheers Si.
[Edited on 3/1/12 by Strontium Dog]
http://s187.photobucket.com/albums/x319/zephyr2000/General%20forum%20uploads/?action=view¤t=3DEngine.mp4
imp paul
posted on 3/1/12 at 07:36 PM |
you could use low compression talbot sunbeam head .with hepolite or custom cp or je pistons wills rings block kit phosphor bronze oil pump kit
.talbot 930 block as its better and stronger with more webs and some nice 36mm carbs have seen a few fast engines like this that are turboed hope all
goes well you could talk to ben boult he is a top chap and he lives imp engines
good luck
paul
here is 1 http://www.youtube.com/watch?v=pvcTFlWVKUw
[Edited on 3/1/12 by imp paul]
chrisimp
posted on 3/1/12 at 09:18 PM |
Hi all,
Ben posted that for me as I hadnt managed to go through the registration for this site which I have just done.
thank so far for the input, regarding wills ring and block strengthening, its just not needed, its overkill for a turbo engine which in comparison to
an imp N/A engine due to the low revs used (6k compared to 11k)
Heres my car which one person will recognise.
And heres the engine bay shot from a year or two ago, it kept changing but you get the idea, ran for 4 years no issues and great fun
Now My new issue is that the imp has lost its engine to my new G15 project and the imps getting rebuilt to HSA modified regulations going to run N/A
1040 twin webers etc etc with lots of internal engine mods including ones mentioned above.
Imp now currently looks like this..... a little shorter
Im rebuilding it with a different kit from Paul.
The ginetta is the main issue in regards to carb selection due to the chassis legs being closer to the engine meaning the SU carb wont fit (sold on to
fund other things) so now looking for another smaller neater solution.
pictures so far
new smaller turbo than the imp set up, Im going for a slightly lower psi on this one 10psi not 14 the imp ran at, but this time its on megajolt
So basically when it comes to the whole imp engine and turbos im pretty clued up and have learnt a great deal over the years but never looked into the
use of bike carbs before or megajolt for that matter haha, lots to learn once again but hopefully you guys will be able to help, ben seems to think
you will be able to
Thanks again guys for your input so far, look forward to hearing more and hopefully getting somewhere to getting fuel back in my engine lol.
Chris
imp paul
posted on 3/1/12 at 09:47 PM |
hello mate and welcome to the site lots of good people on here. its easy going and all sorts of builds this is the home of my imp more so than the imp
club . looks like you have got the bug lose the steel lol
cheers paul
001Ben
posted on 3/1/12 at 10:28 PM |
Welcome to the site Chris.
The chaps and chapettes on here are very knowledgeable and will be able to answer most questions, as you will find out as you spend some more time on
here. So come on all, which bike carbs are suitable for Chris's application
imp paul
posted on 3/1/12 at 10:48 PM |
Early r1carbs seem to be good for use with turbo motors that is a good starting point so its seems also locost lol here is a bit of info on the r1
set up http://www.turbo-bike.net/
[Edited on 4/1/12 by imp paul]
