Author: Subject: Stainless steel exhaust "S" bend
se7ensport
posted on 8/1/12 at 01:40 PM Reply With Quote
I'm in need of an "S" bend in stainless steel to mount my silencer, the pipe needs to be 63mm ID, dimension "X" is 30mm and dimension "Y" is 180mm
exhaust bend
exhaust bend
Alex
[Edited on 8/1/12 by se7ensport]
designer
posted on 8/1/12 at 03:14 PM Reply With Quote
Why not use a flexible if it is not visible outside the car?
se7ensport
posted on 8/1/12 at 03:47 PM Reply With Quote
I'd initially planned to use flexible pipe, but it will be visable from the outside and load bearing as I don't want to mount the silencer front and rear.
Chippy
posted on 8/1/12 at 04:04 PM Reply With Quote
You could try contacting OJZ engineering, they do a vast range of parts, and may even do you a special. Check out their web site, but DO NOT send them an email as you will never get an answer, phone instead. HTH Ray
minitici
posted on 8/1/12 at 04:16 PM Reply With Quote
Chop a 90 degree bend, rotate the two halves and re-weld.
se7ensport
posted on 14/1/12 at 03:22 PM Reply With Quote
Wunoff sorted me out with this, not cheap at £60 (£35 for the work, £15 delivery and £10 vat), but it does the job nicely:
Link pipe
Link pipe
