New Topic New Reply
Author: Subject: P100 Chassis paint
DixieTheKid
posted on 10/1/12 at 12:59 PM Reply With Quote
P100 Chassis paint
Hi all,
Looking for the best option for paint to do my chassis. Its back from the blasters later today so i need to get it covered. Many thanks
COS IT'S Worth IT
jossey
posted on 10/1/12 at 01:09 PM Reply With Quote
cant u get it powder coated?
David Johnson
DixieTheKid
posted on 10/1/12 at 01:23 PM Reply With Quote
I need to make up some backets and weld to them to the chassis to to install the sierra rear beam. So may be ill have it powdercoat much later on and when i have the dosh. Many thanks anyway. Is hammerite an option and then wax?
COS IT'S Worth IT
posted on 10/1/12 at 01:26 PM Reply With Quote
Chassis black ladled on with a big brush over a coat of red oxide. Keep it simple and durable.
DixieTheKid
posted on 10/1/12 at 01:32 PM Reply With Quote
Sounds like a plan. Thanks. Is chassis black a proper paint?
COS IT'S Worth IT
Bluemoon
posted on 10/1/12 at 01:39 PM Reply With Quote
Chassis black is a generic name for well chassis paint (not hepfull! but paint supplier will point you in the correct direction).
You will still want to blast the chassis for best results..
DixieTheKid
posted on 10/1/12 at 01:52 PM Reply With Quote
Yep its being blasted today.
COS IT'S Worth IT
mcerd1
posted on 10/1/12 at 02:27 PM Reply With Quote
this stuff if your budget will stretch to it: http://www.frost.co.uk/automotive-rust-products/por15-rust-solutions/por15-chassis-painting-kit.html
DixieTheKid
posted on 10/1/12 at 02:49 PM Reply With Quote
Thank merc, are you still after some cossie bits?
COS IT'S Worth IT
mcerd1
posted on 10/1/12 at 02:58 PM Reply With Quote
^^ I'd love a complete head for an NA cossie build - but I also need a new boiler and bathroom so I think that'll have to wait
oh and I should have added this stuff to the above http://www.frost.co.uk/por15-prep-ready-946ml.html
it work really well on the small bits I've done (left them soaking in it for a few hours after blasting) - might be a bit trickier to use on a whole chassis though.....
[Edited on 10/1/2012 by mcerd1]
Benzine
posted on 10/1/12 at 03:08 PM Reply With Quote
Epoxy mastic 121 onto blasted metal is the best stuff i've ever seen. I used rollers and the finish was great on blasted metal (i brushed some of it and it was okay but nowhere near good as rollered)
snakebelly
posted on 10/1/12 at 04:42 PM Reply With Quote
if you intend to grind and weld on it i would stick with a good coat of red oxide until its 100% finished then por15 or chassis black after its totaaly finished.
DixieTheKid
posted on 10/1/12 at 04:52 PM Reply With Quote
Well my man, ive got just the very thing you need. I have a bare head, measures about 138.2 which is ideal of a N/A although your need to find a set of journals for it (i do have them although i cannot find them). Ive also 2 or 3 YBB blocks, alloy sump, crank rods & pistons if your interested.
COS IT'S Worth IT
mcerd1
posted on 10/1/12 at 05:03 PM Reply With Quote
I'll keep you in mind for when the funds allow for the next upgrade
I've got everything apart from the head bits (i.e. head, valves, cams, pulleys, top cover etc....) - but I guess I should get it on the road first and upgrade it later :lol:
DixieTheKid
posted on 10/1/12 at 06:59 PM Reply With Quote
She will be a beast!
COS IT'S Worth IT
posted on 10/1/12 at 07:15 PM Reply With Quote
Por15 followed by the Hardnose paint from Frost's
New Topic New Reply
