bccox18
posted on 22/1/12 at 03:58 PM |
FS: Clearout
Hi
Nearing the end of my Tiger Cat rebuild and thought it best to have a clearout of the bits and bobs I'm not going to use.
1. Alloy Header Tank - £30
Diameter=11cm
Height = 18cm
Standoff Bracket =8cm
Bottom Connection = 25mm
Side Connection= 16mm
2. Pinto Starter - £30
3. Low Back Fiberglass Seat - £30
The seat is in OK condition, with 3 chips in the seat rim (pictures below) and various marks from being in storage.
Collection Only for this item due to size.
Width at front=34cm
Width at Thighs=31.5cm
Width at Hips=35cm
Width at Shoulders=36cm
Length of seat base=48cm
Length of seat back=54cm
Front Riser=12cm
4. Elise Stack Gauge Set with Temperature Sensor and cowl - £50
The connector on the gauge has been modified to add a loom and 25 pin D-type to make connection easier.
The cowl is in good condition, but some light scuff marks from being in storage.
I also have pinout and other sensor / wiring details that I can provide if needed.
5. Alloy Push Button Switches - £5 Each
1 x Heated Rear Window
1 x Rear Fog
1 x Front Fog
1 x Lights
All prices are excluding postage, which will be at cost.
Please let me know if you have any questions.
Bob
[Edited on 22/1/12 by bccox18]
wombat
posted on 22/1/12 at 04:06 PM |
u2u sent
Davg
posted on 22/1/12 at 04:33 PM |
Hi Bob
can I take the rear fog & the light switch please.
cheers D
Davg
posted on 22/1/12 at 05:32 PM |
Sorted thanks Bob
