Author: Subject: Master Cylinder Size
leon51274
posted on 23/1/12 at 11:15 AM Reply With Quote
Morning Chaps
I'm after some advice/recommendation if at all poss. Currently in the process of rebuilding my locost and i was wondering whats the best master cylinder to use?
Set up will be m16 callipers to front and standard ford sliding calliper/ disc conversion to rear.
I know there is much talk of bigger pistons etc but i'm useless at knowing whats got whats.
Any advice much appreciated.
Leon
Mal
posted on 23/1/12 at 05:20 PM Reply With Quote
The standard mastercylinder bore that Westfield use is 0.7".
As you probably know the smaller the master cylinder bore the less force is needed to develop a given pressure.
