Author: Subject: EMERALD to KOSO RX2N Tacho signal?
Nash
posted on 25/1/12 at 09:54 PM Reply With Quote
Evening all, I am trying to get a decent tacho output to my newly installed KOSO RX2n dash. Someone suggested taking a feed from my ECU. (Emerald K6). The output signal comes from pin 12 on the K6 wiring plug and is a 0~12V pulsed output.
I am a little less clear about the KOSO wiring diagram. It says the Brown wire is the RPM wire.
My question is can I directly connect the brown wire from the KOSO to output 12 on the K6? If so, do I need to consider anything else? I realise my question may be vague but there are two reasons for that,
1. The KOSO wiring diagram is "limited"
2. Electrics are no my strong point
Any / all help gretefully received.
.............Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
jeffw
posted on 25/1/12 at 10:24 PM Reply With Quote
Should be fine....connect it up
femster87
sorry not a real answer but I have a race technology dash and I have taken the tachometer output from my ecu to the dash RPM cable and it seems to work ok with a little tuning on the dash
jeffw
posted on 25/1/12 at 10:30 PM Reply With Quote
the low-current switched output from the K6 will not damage the RX2N so connect it up and it should work fine.
Nash
posted on 25/1/12 at 10:34 PM Reply With Quote
Thanks Jeff et al, I'll give it a go tomorrow.
........Neil
jeffw
posted on 26/1/12 at 06:29 AM Reply With Quote
Give me a shout if you have any issues.
ashg
posted on 26/1/12 at 08:44 AM Reply With Quote
yep just connect them together. tacho out on my ecu is directly connected to my koso and the rpm readout is rock solid. on the koso go into the settings and change it to 4cyl 4 stroke and low level input and it will work spot on.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Rosco
posted on 26/1/12 at 12:02 PM Reply With Quote
I hooked up my KOSO Rx2n to the taco output from my OMEX600 and it works fine,
Nash
posted on 26/1/12 at 06:35 PM Reply With Quote
Thanks all. Just got in will have a look after dinner
