JeffJeffers
posted on 2/2/12 at 03:34 PM |
Headlight mount
I have just fitted my new headlights and I'm a little unsure about the mounting bolt.
![](/galpreviews/WP_000248.jpg) ![Headlight bolt](/gallery/WP_000248.jpg) Headlight bolt
Does the mounting bolt need to be covered for the IVA? If it does what do people use?
whitestu
posted on 2/2/12 at 04:01 PM |
I covered mine for SVA with some large nut covers.
rodgling
posted on 2/2/12 at 04:05 PM |
It will fail unless you cover it. I used a bit of flat rubber cable tied around it. Rubber hose would be better.
dunk3
posted on 2/2/12 at 04:13 PM |
Yes it will fail the IVA like that. I used a cable gland pushed over the nut, and it passed the IVA. hope this helps.
JeffJeffers
posted on 2/2/12 at 08:03 PM |
Thanks all. After googling what a cable gland was, I stopped at B and Q and bought one of these kits.
The plastic part will work perfectly. Not sure what I'll use the rest of it for!
dunk3
posted on 2/2/12 at 09:10 PM |
That will do the job mate, I should have explained it a bit better, sorry mate.
