Author: Subject: Do I need an anti run on valve
dnmalc
posted on 10/2/12 at 09:15 AM Reply With Quote
I am stripping out the wiring loom and planning to go to bike carbs so I suspect that I don't need to fit the anti run on valve am I correct?
whitestu
posted on 10/2/12 at 09:38 AM Reply With Quote
Bike carbs don't have them so I don't think there is any way you could fit one.
dnmalc
posted on 10/2/12 at 11:14 AM Reply With Quote
That was my thinking but clearly as ford think they are necessary for unleaded fuels there is some disadvantages in not fitting it. I assume it is failure to stop cleanly but are people actually experiencing this? Remember Ford never fit anything if they can leave it off!
whitestu
posted on 10/2/12 at 11:39 AM Reply With Quote
No problems with mine - When I switch offf it stops!
Stu
ashg
posted on 10/2/12 at 03:45 PM Reply With Quote
are you sure its not the alternator back feeding through the battery light in the dash. that is what usually causes run on as it keeps the ignition system live when the key is removed. a simple diode from maplin in the batter light wire from the alternator will cure it
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 10/2/12 at 09:24 PM Reply With Quote
I'm using throttle bodies on my Xflow without an anti run on valve and have no problems
