thunderace
posted on 10/2/12 at 01:47 PM |
how to i get this out 1.9 CDTi 150, ALTERNATOR
Vauxhall 1.9 CDTi 150, ALTERNATOR REPAIR,RECTIFIER REPACEMENT
i need to remove my alternator on my mrs car but cant work out how to get it out,i can remove the belt by removing the airbox and then removing the
engine mount to gain access to the tensioner but have no idear how to get the thing out?
MkIndy7
posted on 10/2/12 at 02:15 PM |
The alternator on my old Redtop has to come out from below, a very tight squeeze between the driveshaft, Exhaust and steering rack. Only way
I've kind without taking the inlet manifold or engine out!.
Obviousley a different engine entirely but Vauxhall may still use the same idea.
mookaloid
posted on 10/2/12 at 02:41 PM |
link for a thread on a website which I found by googling
which might help
adithorp
posted on 10/2/12 at 02:53 PM |
Nightmare!
I think from memory when we've done them, they go down but won't pass the o/s driveshaft so you have to undo the ball joint and pop the
innner cv out which just lets it past. Don't quote me on that though...
http://jpsc.org.uk/forum/
locoR1
posted on 10/2/12 at 03:42 PM |
Had to replace mine on my Sri 150 it will come out the top but its not easy! to get mine out i removed the fuel filter and its mounting bracket,
remover the o/s engine mounting supporting the engine with a trolley jack, if i remember right you can gain some clearance by lowering or raising the
engine also had to gently tweak the air con pipes.
Good luck
Check out my CB500T Cafe Racer build diary
ian locostzx9rc2
posted on 10/2/12 at 04:07 PM |
Comes out of the top You have to remove fuel filter assy.
jacko
posted on 10/2/12 at 06:11 PM |
Look on the vectra c forum lots of info on there
Have you checked with the main dealers they renewed mine because vauxhall [ GM ] had a recall when you take the car in for a service
Jacko
http://www.justanswer.com/uk-car/27azy-replace-vauxhall-vectra-1-9-cdt-alternator.html
http://www.vauxhallownersnetwork.co.uk/index.php?threads/vectra-c-1-9cdti-alternator.210224/
[Edited on 10/2/12 by jacko]
dray13dad
posted on 10/2/12 at 06:30 PM |
remove air box,engine mount cam covers jack engine up and out pops alternator from the top.. whilst your there may as well do cam belt as guess your
up around 70 -80 miles. thats the norm time for alternator to pack up..
thunderace
posted on 10/2/12 at 06:51 PM |
no its done around 45,000
thunderace
posted on 10/2/12 at 06:58 PM |
i cant see anyway of removing it without removing the fuel filter ?
