Author: Subject: R1 Turbo Bec Battery
001Ben
posted on 12/2/12 at 09:29 PM Reply With Quote
I have a 2001 R1 turbo engine in my kit with a standard R1 battery and it is struggling to start so I think its time to change the battery.As it has always struggled to start especially since the addition of the turbo and other stuff i think its time to uprate the battery a little, what are the do's and don'ts of uprating the battery?? I have read a few posts that have said dont put a car battery on it.
The standard battery spec is:
Voltagte : 12 V
Capacity : 10 Ah
Cold start peformance: 180 EN
I was thinking of uptrating it to this battery but im not too sure whether it will actually make much of a difference:
Voltagte : 12 V
Capacity : 14 Ah
Cold start peformance: 220 EN
as can be seen here: battery shop
big_l
posted on 12/2/12 at 10:17 PM Reply With Quote
Odesey red top 25 mate well worth the money .
And it will start a jumbo jet !!!
Check out my blog mnrvortxhayabusa@blogspot.com
001Ben
posted on 12/2/12 at 11:20 PM Reply With Quote
like this ODYSSEY RACING 25 RACE BATTERY RED TOP FREE POSTAGE AVA | eBay??
is there much difference between the redtop 25 and this ODYSSEY PC535 HIGH PERFORMANCE PURE LEAD BATTERY | eBay as my terminals are the otehr way around
PAUL FISHER
posted on 13/2/12 at 12:01 AM Reply With Quote
Ive just bought one of these for my Aries blade, also had one fitted to one of my old Indys, with no problems, they also sell some nice alloy battery trays to go with them
http://www.rallydesign.co.uk/product_info.php?products_id=14752
Studlygudfuk
posted on 15/2/12 at 08:20 AM Reply With Quote
If you have a turbocharged engine then it is lower compression & thus should be easier to turn over than a standard engine. If your existing battery is failing to turn it then you have an issue.
Either the battery is Kaput & simply needs changing or something is wrong with the starter system or frictional turning of the engine.
