v832b
posted on 15/2/12 at 01:04 PM |
Garage Clearout Various
Ford type 9, 5 speed, from 2.3 V6.
Ford type 9, 2.8 V6 5th gear, when fitted to a 4 cylinder box, 5th is about 0.9.
Pair of yellow rear arches to fit cortina / Sierra axle.
Pair of stuart taylor front arches - Yellow - new.
Escort Mk2 axles casings
Escort Mk2 rear brakes 8" and 9"
Escort / english diffs all ratios except 4.1
1600 GT Xflow exhaust manifold
Sierra 2L injection head skimmed 100 thou with twin choke inlet
Rover V8, 3500S complete need rebuild
Holley carb for rover V8 390 I think.
Pinto dizzy
Pinto lighten fly wheel
XJ6 diff
70s Le man style prototype sport car body, rear engine 4 piece complete.
Niki twin choke carbs.
Iveco 2.5 turbo diesel engine
Jag coil overs
Mini adjusable shocks
2.25" springs various lenght and weights
Princess 4 pot calipers
if interested email v832b@tiscali.co.uk
daviep
posted on 15/2/12 at 01:14 PM |
Where are you located?
samjc
posted on 15/2/12 at 01:16 PM |
How much for the type9 v6 gearbox and is it only the bell housing thats diffrent or is the box ratios diffrent.
JAMSTER
posted on 15/2/12 at 01:17 PM |
pinto flywheel how much posted to peterborough what does it weigh any english lsd diffs
thanks
[Edited on 15/2/12 by JAMSTER]
jonrotheray
posted on 15/2/12 at 02:17 PM |
Got a 3.54 english diff?
SALAD
posted on 15/2/12 at 05:07 PM |
+2 for location.
Interested to see the Le Mans prototype body....
samjc, the v6 box has a longer input shaft, can't remember the difference.....
dave r
posted on 15/2/12 at 05:26 PM |
quote: Originally posted by SALAD
+2 for location.
its about an inch longer
i have a suitable machined spacer that i have just removed from mine that is available if needed
dave
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
carlknight1982
posted on 15/2/12 at 05:36 PM |
Is that 2l head for the pinto? If so how much and where are you located
Logic will get you from a A to B
Imagination will take you everywhere.
les g
posted on 15/2/12 at 07:16 PM |
is it a points dizzy
if so i,m after it
cheers les g
JAMSTER
posted on 16/2/12 at 06:52 PM |
is there anybody there
samjc
posted on 18/2/12 at 03:35 AM |
Cheers, its for a duratec v6 but long way off needing it plus low on funds but if at a good price may consider storing it.
maccavvy
posted on 18/2/12 at 07:51 AM |
what length and poundage are the springs ??
[Edited on 18/2/12 by maccavvy]
NigeEss
posted on 18/2/12 at 09:32 AM |
Following This post I need a diff.
What ratios have you available and how much ?
Nige
