swanny
posted on 17/2/12 at 11:15 AM |
attaching cables drilling roughcast walls
Hello all,
just a quick question here regarding roughcast exterior walls.
had a quote for installing a digital aerial and other stuff which seemed steep (100 quid an hour?) so have decided to do most of cabling and other
bits myself and just get the guy up on the chimney to replace old analog aerial and connect up my cables.
This will mean drilling into and then attaching cables to our roughcast exterior walls.
aerial guy seemed quite nervous about drilling these to make holes for the cables incase loads of roughcast came off in the process. there is also the
issue of trying to secure cables to the same wall.
i wont be running huge amounts of cable as i intend to do the link from front to back of house via the loft but obviously want the visible bits to be
neat. (existing cabling was done prior to roughcast 2-3 years ago)
any experts on here suggest clever ways to drill or attach cables to this? or do i just need to be careful and get on with it?
thanks
paul
posted on 17/2/12 at 11:43 AM |
Why drill it? You're only attaching a cable to the wall... Is it not possible to attach the wires to the wall with one of the multitude of glues
/ adhesives available.
swanny
posted on 17/2/12 at 11:44 AM |
i need to drill the holes to get the cables into the house itself. (should have said we are adding aerials to rooms where there currently isnt any)
paul
cliftyhanger
posted on 17/2/12 at 12:16 PM |
Maybe he has a massive sds drill or something that is damaging. If concerned, drill without hammer action or a mild one, not too aggressive.
tradesmen hate it when they get the blame for damage which does regularly happen when drilling, especially on a suspect area. Roughcast was often
applied over poor quality bricks too, another cause for concern.
Confused but excited.
posted on 17/2/12 at 04:54 PM |
swanny, there is no such thing as a digital aerial. If this is what you have been told by an installer, find another one.
If however you are having problems with reception and not getting all the channels,, then you may need to change your original aerial for a wideband
aerial.
If you want to feed several TV sets then just use one aerial and a powered distribution amplifier.
HTH.
daniel mason
posted on 22/2/12 at 08:29 PM |
what type of house do you have swanny? stone or cavity walls? and where are you trying to get wires from and to? u2u me with details and ill explain
the best and most cost effective way of doing what you want.
