Author: Subject: rear light direction
RMarine
posted on 26/2/12 at 12:02 PM Reply With Quote
hi, can anyone tell me if the rear tail lights need to be pointed in a perticular direction? as in most 7 type car the back of mine is at a sight angle. the lights i am fitting are these:
http://www.cbsonline.co.uk/product/70mm_L%7CR_Style_Set_Of_Six_RL24
will i need some sort of mounting backet?
Its all Mark Evans fault......
NigeEss
posted on 26/2/12 at 12:34 PM Reply With Quote
They are standard Land Rover Defender items that screw straight ot the bodywork.
Usually mounted with the screws horizontal as it looks neater.
Go to Paddockspares.com and you'll get them for about £3 each.
Indicator
Sidelight
Stop/tail
[Edited on 26/2/12 by NigeEss]
RMarine
posted on 26/2/12 at 12:54 PM Reply With Quote
Thanks chap, i aready have the lights and yes i paid well over the top...lol
But what about the direction of the lights? is it ok for the lights to be fitted to the bodywork directly because that would make them point skywards
snowy2
posted on 26/2/12 at 07:54 PM Reply With Quote
there is no limit to how they are fitted just to angles of visibility and minimum heights, how you fit them is up to you.
sometimes you are the pigeon, most of the time the statue.
RMarine
posted on 26/2/12 at 08:34 PM Reply With Quote
Thanks chap
daviep
posted on 26/2/12 at 08:37 PM Reply With Quote
Fog light must be mounted vertical, cannot be at angle up or down.
Davie
