Author: Subject: Diff output stubs
koiking125
posted on 27/2/12 at 09:12 PM Reply With Quote
Diff output stubs
Ok, so I have searched the forum but cannot seem to find a definitive answer. Can I swap the 100mm lobro output shafts from my 3.62 LSD diff into a push in 3.38 open diff without any problems. If its not possible is the only option to have the crown wheel and pinion from the 3.38 fitted into the LSD unit?
Thanks in advance Kevin.
MK Owners Club Member (Frosty) No.1159
phelpsa
posted on 27/2/12 at 09:40 PM Reply With Quote
One side stub is shorter on the LSD so the spline won't fully engage (or so I have been led to believe). You need to find a non-lsd flange type diff to swap them over.
Kev99
posted on 27/2/12 at 09:46 PM Reply With Quote
As above thats what ive done with mine they do come up on the bay now and again
koiking125
posted on 27/2/12 at 09:58 PM Reply With Quote
Right so I need another diff, non lsd with lobro outputs or 1 long output shaft. Anyone got a knackered diff or just an odd output shaft knocking around?
Chippy
posted on 27/2/12 at 10:56 PM Reply With Quote
I have a pair of them, complete with the circlips. Regards Ray
[img]
[/img]
[Edited on 27-2-12 by Chippy]
koiking125
posted on 28/2/12 at 12:35 PM Reply With Quote
Chippy you have U2U
koiking125
posted on 11/3/12 at 09:30 PM Reply With Quote
3.38 diff all cleaned up and painted. Chippys output shafts cleaned,painted and fitted. 3.62 diff removed and replaced with nice shiny 3.38. First run out this afternoon of 50 miles or so and I am well happy.
Liam
posted on 11/3/12 at 11:24 PM Reply With Quote
Out of interest, how come you didn't just make a 3.3 LSD? Dont like the LSD, or it's borked anyway?
koiking125
posted on 12/3/12 at 12:35 PM Reply With Quote
Liam,
I am going to see how this one goes for the summer and if i decide i prefered the LSD i will whip it out and do it over the winter.
First impressions are that the new one is alot tighter than the LSD which has quietened the gearchange down. It has also brought the revs down quite a bit which will make it a bit more pleasurable over a long run.
Cheers Kev
