sky12042
posted on 28/2/12 at 09:16 PM |
Dual Mass Flywheel Help
need advice
purchased a new tin top the other week, Honda crv 2.2diesel 57 plate, on first good run out noticed clutch slipping when above 2k revs, so took it
back to garage brought it from and they said yeah clutch is slipping bing it back next week and we will replace clutch plates, so went in today, they
ring up later to say that the dual mass flywheel is about on its limits, so they said while the clutch is out do i want them to replace DMF at
£450.
Question is should this be part of the clutch related repair as only had it 1 week, and i've heard that DMF can cause slipping/worn clutch, if i
do have to pay is £450 a good price, if i dont bother with new DMF, what is the likely outcome, dont want to end up replacing DMF is 6 months time.
Help.
Andy.
PSpirine
posted on 28/2/12 at 09:22 PM |
I would replace the DMF purely because it's literally a 5 minute job if they're already doing the clutch (there should be no additional
labour cost for them doing the DMF at the same time).
Not sure what they mean by "on the limits" - the actual dual mass damping springs/mechanism tends to fail relatively catastrophically and
isn't a part that "wears" out.
Check how much the DMF costs on eurocarparts (can provide a discount code via PM if you want - not sure if it works on this category though) -
I'd expect the garage to be able to get it at least as cheap as that for the same OEM brand.
paulf
posted on 28/2/12 at 09:23 PM |
I would tell them to change it as well at there expense or refund your money.What sort of warranty did they give? i would expect any fault to be
covered for at least 3 months and if the flywheel is said by them to be on its limit then they need to replace it .
Paul
PSpirine
posted on 28/2/12 at 09:25 PM |
Just checked - £359.99 for a Luk DMF on eurocarparts, £305 with discount. Both of these are including VAT, so I'd expect the garage to be able
to get it for about £260.
As I said, if they're doing the clutch, I certainly wouldn't pay more than a tenner on top to swap the DMF...
fesycresy
The DMF will start rattling like a pig and then break up!
How much are they from the motor factors? Looks like the garage could be getting some money back they're losing on the clutch.
sky12042
posted on 28/2/12 at 09:26 PM |
so do you think this should have been noticed before they sold it to me, and i should try and get it done under there waranty.
PSpirine
posted on 28/2/12 at 09:28 PM |
Paul
Just read Paul's post and then re-read the OP... if you bought the car a few weeks ago from the garage, they should fix everything for free.
EU mandates a warranty when purchasing a used car from a dealer. Most will only offer 3 months but that's plenty in your case. Get a written
quote saying that the flywheel needs replacing as well and then get them to change everything free of charge.
Not sure what the specific law to quote is but I'm sure someone will come along shortly
austin man
posted on 28/2/12 at 09:30 PM |
go for it under warranty, a lot of people change the DMF for a solid one it may be worth considering this option if a solid one is available
sky12042
posted on 28/2/12 at 09:31 PM |
i got a 2 year rac warranty with the car, but i think they are trying it on with the DMF, surely the sale of goods act state that it must be fit for
purpose at sale, if not then the seller should be given the chance to rectifie, i think thats right anyway...
posted on 28/2/12 at 09:32 PM |
There are specific angular movement limits for DMFs if the flywheel is outside the limits then there is no point in fitting a new clutch without
also fitting a new DMF.
They have sold you car with vital parts worn outside the accepted limits so normally I would say if you have had the car less than 2 months the
cost of the parts is down to them not you, either they fix it or give your money back.
PSpirine
posted on 28/2/12 at 09:39 PM |
Take it back, get them to fix both or take the car back for a refund (apparently both within your rights!)
http://www.adviceguide.org.uk/index/your_world/consumer_affairs/buying_second_hand_vehicles.htm
http://www.which.co.uk/consumer-rights/sale-of-goods/your-rights-buying-second-hand-cars/second-hand-cars-your-rights/
ian locostzx9rc2
posted on 28/2/12 at 09:45 PM |
If the Dmf is at the limit of max wear tolerance then it needs changing, as for solid flywheel conversions I wouldnt touch them I have seen broken
crankshafts when these have been fitted!. I would like to think the dealer that sold you the car should repair the car free off charge as you have
only had it a short time.
perksy
posted on 28/2/12 at 09:46 PM |
As above
Its not 'fit for purpose' as it stands and pretty sure it will come under the sale of goods act
They either put it right and guarantee the work or you want a refund
Presumably if it has an RAC warranty it should have all been well checked before being offered for sale ?
sky12042
posted on 28/2/12 at 09:47 PM |
cheers for the advice will have a word with them tomorrow, think it should be done under there sales warranty, as was like this when sold so surely
not fit for purpose.
will let you know outcome
Andy.
motorcycle_mayhem
posted on 28/2/12 at 10:21 PM |
Please do let us know.
I guess you've found out why the previous owner of the car decided to part with it....
craig1410
posted on 28/2/12 at 11:52 PM |
I agree they should repair the car without any cost to you.
However, how will you actually know if they have replaced the DMF or re-fitted the original ? If they aren't going to get any money from you for
the job then they might be tempted to just put it back together and hope for the best.
I'd be inclined to offer to pay something towards the repair (say £100) but only on the condition you can witness the new DMF being taken from
its packet and fitted to the engine. Maybe I'm being too cynical but depending on the garage involved my cynicism may be justified. £100 is a
small price to pay for the peace of mind that you now have a brand new DMF and clutch which you wouldn't otherwise expect to have in a 5 year
old car.
HTH,
Craig.
snapper
posted on 29/2/12 at 06:32 AM |
Manufacturers specify changing DMF, clutch plate and cover and on a Ford the hydraulic release mechanism.
I have just had the lot changed on a Mondeo as some Numpty only changed the clutch and whilst it looked ok the starter got filled with DmF dust 3
times then the DMF started breaking up, cost £650 cash
I eat to survive
I drink to forget
roadrunner
posted on 29/2/12 at 10:16 AM |
Sorry to hijack the thread, but I have a resonating rattle coming through my gear stick at the same revs in every gear, it starts at 3200revs then
tapers off over 4000revs. I have checked exhaust and replaced all engine and gearbox mounts, and still the vibration is there, it even vibrates when
in neutral.
I was starting to think it was the dual mass on its way out, but its been the same for the last year without getting worse.
If a dual mass is on its way out does it go fairly quickly.
Brad.
sky12042
posted on 29/2/12 at 07:32 PM |
Update.
The garage have agreed to replace the DMF under warranty, but only after a lot of shouting and ranting about it.
rang our local Honda dealership and spoke to there service manager and he confirmed that if your replacing the clutch then you should replace DMF as
well.
so a Big Thank you to you guys, would not of had the courage to argue about it without the confidance of the forum.
