sebastiaan
posted on 6/3/12 at 07:08 PM |
LED bulbs
As part of my winter rebuild I'm looking at fitting LED-type replacement bulbs to my rear lights (tail, stop and indicator. All the round
landrover defender style units).
Anyone got a recommendation?
Thanks!
Sebastiaan
omega 24 v6
posted on 6/3/12 at 07:35 PM |
Not really a recommendation just a warning that your indicators will not work unless you ballast resistor them or fit a time based flasher unit which,
in turn will not warn you when a bulb fails.
sebastiaan
posted on 6/3/12 at 08:17 PM |
Thanks for that. I was planning to get a led flasher relay at the same time to solve that problem. I'm basically looking for some first hand
experience with the led replacement bulbs. Are they brighter /more visible than standard incandescent bulbs?
loggyboy
posted on 6/3/12 at 08:32 PM |
Get some that have LEDs at lots of angles, as when I got some a few years ago for my Tintop, they were great when you viewed them within a few degrees
of perpendicular, but appeared very dim at more acute angles. This was down to almost all the LEDs pointing straight backwards.
spiyda
posted on 7/3/12 at 12:13 AM |
quote: Originally posted by sebastiaan
Thanks!
Sebastiaan
If you can measure the biggest diameter disc you can fit inside the lens...
it is probable that the indicator boards I make for Minis will fit
the indicator from the MK1 front (about 47mm dia)
https://www.spiyda.com/magento/index.php/classic-mini-parts/individual-lights/classic-mini-led-front-indicator-board-mk1-on.html
The stop and tail would need a new board, but I could rustle one up in a day or two
They use 6 off 10mm 0.5 watt wide beam LEDs for the brake and indicator..
brighter, more visible and longer life than the standard bulb... and a LOT cheaper than the NAS LED lights
cost would be £11 per bulb replacement (the same as the mini ones when I put the price up this weekend)
Chris
www.spiyda.com
ps I also do the ballast resistors and ususlly very good LED flasher units but I am out of stock of those for a week or so
[Edited on 7/3/12 by spiyda]
home page - http://www.spiyda.com
build diary - http://www.16vminiclub.com/forums/showthread.php?t=4427
Nothing is so simple it can't be made more complicated !
owelly
posted on 7/3/12 at 01:57 AM |
I bought some stop/tail light replacement LEDs and the way they were connected inside, made a connection between the tail lights and brake lights
which meant my high level brake light came on dim with my side lights and then bright with the brake lights. It also meant that the brake light
circuit was conneced to both side light circuits and defeated the fuses.
http://www.ppcmag.co.uk
loggyboy
posted on 7/3/12 at 09:24 AM |
These are the type I bought, which ha da very narrow angle:
Which I then replaced with ones like this that have extra LEDs at side:
It will very much depend on your lenses, as if you have reflectors you may want ones with lots of LEDs at the side to bounce off and spread the
light:
Either way they are cheap as chips on ebay - 99p for orinental based sellers or £2-3 for UK.
spiyda
posted on 7/3/12 at 10:27 AM |
To work properly, they need diodes to prevent the stop and tail circuits interfering with each other...
thats a definite MOT fail
