Author: Subject: replacing lower ball joint with a rose joint, drill out the taper?
MK9R
posted on 8/3/12 at 09:05 AM Reply With Quote
I'm replacing the lower ball joint on the fury front unpright with a rose joint, the tapered inserts I got dont fit the escort upright (made for cortina I think), is there any readson why I shouldnt just drill out the taper and use a standard bolt?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
HowardB
posted on 8/3/12 at 09:11 AM Reply With Quote
Morning Austen,
First guess would be that the taper works just like a morse taper on a drill and as such does not depend solely on bolt tension to stop rotation.
Hope that helps, and sorry if I've spoilt your cunning plan.
Howard
posted on 8/3/12 at 09:31 AM Reply With Quote
What size bolt would you need if you drill out to the size of the bottom of the taper ? It would be better if you got an adaptor and use the same size bolt as the nut that holds the present ball joint.
MK9R
posted on 8/3/12 at 09:38 AM Reply With Quote
Current ball joint uses 1/2", could drill out taper to 5/8", which would leave plenty of meat on upright (widest point of taper is 5/8", rose joint is a 5/8" so just use a decent quality 5/8 bolt.
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 8/3/12 at 09:39 AM Reply With Quote
Originally posted by HowardB
Morning Austen,
the ball in the rose joint allows all the rotation, just like all the other pickups on the suspension
Cheers Austen
RGB car number 9
www.trackace.co.uk
HowardB
posted on 8/3/12 at 09:42 AM Reply With Quote
Morning Austen,
Yes of course, what I meant was that the taper stops the shaft rotation,.. probably only a problem in a poorly maintained system where the ball might seize, or get stiff.
[Edited on 8/3/12 by HowardB]
Howard
mark chandler
posted on 8/3/12 at 10:22 AM Reply With Quote
You can, but would need to ream the hole for a very close fit, better off buying pins to mount the rose joints
MNR link
Like here
MK9R
posted on 8/3/12 at 11:10 AM Reply With Quote
Tried to buy them in the past from mnr, they dont sell them. I can get some made by a chap locally, but I'm just wondering if its really necessary
Cheers Austen
RGB car number 9
www.trackace.co.uk
phelpsa
posted on 8/3/12 at 12:32 PM Reply With Quote
Where did you get the cortina taper adapters? Would you sell yours? I was about to get some made but it would save a lot if hassle if I didn't have to!
Rich J
posted on 8/3/12 at 04:13 PM Reply With Quote
Are these what your after?
1 x ford/105e/100e/cortina/capri/corsair/race/rally/autograss/brisca 5/8' taper | eBay
he also does 1/2" steering arm ones
[Edited on 8/3/12 by Rich J]
Lew The Machine
posted on 11/5/12 at 08:14 AM Reply With Quote
Did anyone find a solution to this?
Im currently looking at the same problem and cant find a design/supplier of these taper adaptors anywhere and i really dont fancy drilling the upright, id like to keep it a bolt on conversion!
ITS FINE! i welded it!
iank
posted on 11/5/12 at 11:01 AM Reply With Quote
Same seller as Rich J pointed out still has them.
eBay Item
Anonymous
Lew The Machine
posted on 13/5/12 at 12:53 PM Reply With Quote
Yeah lol, realised they were still listed on that guys eBay page after I posted up here, only question Ive got is is a 5/8 rose joint a better choice than an M16? As his taper bolts are for 5/8! I've never really messed about with rose joints :-S
