Author: Subject: Seized coilovers
craig_007
posted on 9/3/12 at 07:20 PM Reply With Quote
Seized coilovers
I've just been to try an adjust my ride height but the platforms are seized.
Has anyone got any tips for getting these moving, I tried heat and got the bottom lock ring to move but the upper ring for adjusting the height was solid.
I've left it for tonight and soaked the treads etc in spray grease .
owelly
posted on 9/3/12 at 07:30 PM Reply With Quote
If they are ally, soak them in vinegar, if they are steel, soak in penetrating oil. Try tapping the collars with a small hammer as you turn them.
http://www.ppcmag.co.uk
Dave Ashurst
posted on 9/3/12 at 07:34 PM Reply With Quote
You loosened the grub screw?
austin man
posted on 9/3/12 at 09:26 PM Reply With Quote
make sure you raise the car up and take the weight this also makes them easier
craig_007
posted on 9/3/12 at 09:28 PM Reply With Quote
Yep everything is loose and car jacked up, I'll need yo try again with a decent spanner.
