Author: Subject: Busa Injectors
Custardpants
posted on 10/3/12 at 05:01 PM Reply With Quote
Busa Injectors
Both the pX600 backplate and the reverie backplate foul the top-most secondary injectors my my gen II busa. Is there anything wrong with turning them sideways around 30 degrees as shown in my picture to stop them fouling the airbox backplates? Mk had just shoved it on and it was putting a lot of pressure on them.
thanks guys!
L
Custardpants
posted on 10/3/12 at 07:13 PM Reply With Quote
For reference if anyone finds this through the search engine - it appeared to have no change just now - i'd particularly advise it to avoid the injectors rubbing against the pipercross filter backplate as per the standard MK install.
SJL
posted on 10/3/12 at 07:29 PM Reply With Quote
I was just going through the repair manual to see if the injectors had to orientated a specific way - normally due to spray patterns and it appears they don't have a specific orientation so I would say you are good to go
You will have a U2U shortly
