Author: Subject: DIY Silencer
Chris_R
posted on 24/8/04 at 10:17 PM Reply With Quote
DIY Silencer
Has anyone made one? I'm thinking of making a straight through back box using wire wool to deaden the sound. Don't want it to be too quiet though. Any tips?
It's not for the locost, it's for my Cav.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Viper
posted on 24/8/04 at 10:57 PM Reply With Quote
dont use wire wool, it burns, you can get exhaust waddind it is pretty much the same as loft insulation.
Tim
type 907
posted on 24/8/04 at 11:09 PM Reply With Quote
Back box
I'v got a half made back box in my garage
for an alfa cloverleaf.
I put a straight through pipe on so he could still use the car
while I made the box. He came back the next night and said,
" forget the box, I'll keep the pipe, sounds gorgeous".
Paul G
Too much is just enough
DaveFJ
posted on 25/8/04 at 07:51 AM Reply With Quote
I'll vouch for Paul G's silencers........
When I visited he was in the middle of making a pair for an Aston martin IIRC.... and damn fine they looked too !
Dave
craig1410
posted on 25/8/04 at 12:14 PM Reply With Quote
Chris,
Make sure you use stainless steel wool around the perforated tube and then some form of loft insulation/rockwool material around that. Also, make sure you pack it in really really tightly.
I didn't actually do this myself because by the time I priced the various materials required I was able to buy a ready made silencer more cheaply, even from Demon Tweaks... £57 each for a 5" outer diameter, 625mm long, 3" centre bore straight through glass-pack. It's not stainless but I didn't want stainlessa anyway.
Craig.
Chris_R
posted on 25/8/04 at 05:45 PM Reply With Quote
Thought about just replacing the box with a pipe. Is it legal?
blueshift
posted on 25/8/04 at 05:51 PM Reply With Quote
There's a sound level test for SVA, and I think in theory you can be pulled for having a noisy exhaust fitted post-sva.
It's legal as long as it's not replacing a catastrophic converter and doesn't make too much noise. I don't think they SVA Cavaliers Blueshift.
[Edited on 25/8/04 by Peteff]
ned
posted on 26/8/04 at 08:21 AM Reply With Quote
use the insulation type material, but dn't pack it too tight as it can be noisier! You want the material to absord noise, not let it bounce around/echo in there..
Ned.
beware, I've got yellow skin
Chris_R
posted on 26/8/04 at 05:27 PM Reply With Quote
Cheers guys, thanks for the info. For me louder is better so will give it a go and see what happens.
craig1410
posted on 26/8/04 at 10:23 PM Reply With Quote
Ned,
I was going by what "Simon" said, if you'll pardon the pun. He made up some exhaust silencers for his Rover V8 and realised later that he hadn't packed the cans tightly enough and had to get more wadding. I did a lot of research when considering making my own silencers and a recurring theme was to make sure they were packed tightly and to use stainless steel wool around the perf tube.
Craig.
jmbillings
posted on 27/8/04 at 01:52 PM Reply With Quote
we made one, used to buzz at a certain rpm but worked ok. We've recently replaced it with an MK one, and it sounds *so* much nicer tho!
