Author: Subject: can anyone recomend, lsd additive for plate type lsd
nickw2000
posted on 20/3/12 at 08:48 PM Reply With Quote
been looking around for lsd additive for the clutch plate lsd. the additive will modify the slip between the plates to quiten them down.
cant find much online, who sells it?
cheers
Antnicuk
posted on 20/3/12 at 09:06 PM Reply With Quote
i am no expert but i used valvoline Limited slip gear oil which was recommended by burtons for my atlas LSD. As for additives i have used this with good results, if this is what you mean by additive, its a friction modifier.
Red Line LSD Limited Slip Diff Friction Modifier | eBay
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
posted on 20/3/12 at 09:17 PM Reply With Quote
ISTR Demon Tweeks will sell you the additive or the correct oil.
