Author: Subject: r1 plumbing again 4XV
0hooters0
posted on 23/3/12 at 07:08 PM Reply With Quote
At the moment the plumbing is a big mess so I am fitting new polo rad hoses & tank ..I have looked and read lots off posts for the best way of doing this so I think I am ok.At the moment I have a small pipe from the thermostat to a inlet at the end of the carbs next to the plug not sure what to do with this as most post say the small thermostat inlet/outlet should be plumbed in to the header tank pipe. If so where's
small pipe from the carbs go. car was running BL mini rad and no header tank.
[Edited on 23/3/12 by 0hooters0]
A1
posted on 23/3/12 at 07:50 PM Reply With Quote
do you have a pic of the pipe on the carbs?
on my 4xv there was a small pipe coming out just below the inlet ports on the heads, tapping into the jackets.
0hooters0
posted on 23/3/12 at 08:19 PM Reply With Quote
No photo of end of pipe but you can see the pipe run .photo in archive thanks.
renetom
posted on 5/4/12 at 09:02 AM Reply With Quote
water layout
Hi
This is the water layout on our R1 5JJ Indy.
Works fine. ( see our photo archive)
René
0hooters0
posted on 5/4/12 at 10:12 PM Reply With Quote
thanks
Thanks all done now all new plumbing and gearbox mot and taxed today detling show on Saturday
