lsdweb
posted on 26/8/04 at 04:42 PM |
Zetec - Crank case breather
Hi All
I'm trying to fit a crank case breatehr onto my 2 litre Zetec (the one on the block under the exhaust manifold). Has anybody used anything other
than the standard Ford fitting / valve?
Regards
Wyn
dave1888
posted on 26/8/04 at 05:22 PM |
andyharding is working on an alternative. steel blanking plate with a tube welded on then a rubber tube to catch tank
zetec
posted on 26/8/04 at 05:48 PM |
The valve Ford fit only opens when their is negative presure from the inlet manifold so will in normal use never open if not connected. Dunnels say
just leave as fitted as the engine can breath via the camcover pipe.
lsdweb
posted on 26/8/04 at 06:48 PM |
Dave1888
I have a plate with an oulet welded on, fed into a catch tank. After 4 laps of Llandow in a sprint, the tank was full! This wasn't a good
idea!
Wyn
Thrustyjust
posted on 26/8/04 at 08:04 PM |
Just take the poppet valve out of the small catch tank and cut the end off and then remove the valve and spring.It will now breath open,but leave the
tank on the sideof the block,as this prevents the oil splash from the crank hurtling up and filling your breather tank as other have found.
lsdweb
posted on 28/8/04 at 08:13 AM |
Thanks all
I spoke to Paul Dunnell yesterday - he recommends just blanking off the hole. I'll do that. He did offer (jokingly) to sell me a titanium
blanking plate for £100!!!
Regards
Wyn
