Author: Subject: Electric Locost
Rustymini
posted on 30/3/12 at 03:26 PM Reply With Quote
Electric Locost
I've been away from this site for quite some time so please forgive me if I ask questions that have been answered many times.
I bought the Ron Champion book when it first came out and built the chassis as a college project, however when my working pattern changed the college (assuming that I wasn't going back) used my chassis as tube stock.
A few years ago I decided to have another go at a build. I bought all the tube I needed plus the later edition of the book (and the Haynes Roadster book as well) and it's all sat in my garage since.
Since then I've developed an interest in converting a car to electric power (part of my job is to manage FLT drivers). So why not combine the two? I'm guessing by now that someone must have built an electric locost. If anyone has website or blog addresses for builders who have done it I'd appreciate the info. Or even better - if you've done it yourself I guess I'd like to be in contact with you.
Would building an electric car from scratch have any effect on SVA/ IVA?
designer
posted on 30/3/12 at 03:35 PM Reply With Quote
Electric Lotus 23:
http://www.szott.com/zot2/zot2.html
PAUL FISHER
posted on 30/3/12 at 04:41 PM Reply With Quote
There's a couple of MK Indy electric cars, I had a drive of one once, it was rapid!!!!!!
http://www.youtube.com/watch?v=4ieQ3jzaN3E
russbost
posted on 30/3/12 at 05:05 PM Reply With Quote
There was one in one of the kitcar mags ages ago, probably 5 or 6 years ago, I'll see if i can find the article, but don't hold your breath!
RK
posted on 30/3/12 at 05:33 PM Reply With Quote
What happened to the Westfield electric 7? Weren't they going to have a race series with them?
grafter
posted on 30/3/12 at 07:13 PM Reply With Quote
Here is a link to a good DIY EV site
http://www.diyelectriccar.com/forums/
chris-g
posted on 30/3/12 at 08:36 PM Reply With Quote
South Notts College have an electric MEV that they use to train mechanics.
matt_gsxr
posted on 30/3/12 at 09:26 PM Reply With Quote
So what would be the cost of the electrics for a 100bhp motor and batteries.
I quite fancy it.
ReMan
posted on 30/3/12 at 09:42 PM Reply With Quote
I quite fancy it.
Yea me too
I like the idea and contast to the BEC and escaping the fuel queues!¬
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
steve m
posted on 30/3/12 at 09:48 PM Reply With Quote
Me too, plus i believe electric cars are tax exempt ??
PAUL FISHER
posted on 30/3/12 at 10:34 PM Reply With Quote
The one I drove, I was informed the electric bits cost around £8000
Dangle_kt
posted on 30/3/12 at 11:20 PM Reply With Quote
electric cars arn't cheap - especially for a "toy" car which wont make any savings vs. a ICE(internal combustion) on mileage - cos it'll probably do 1000 miles a year at most.
Plus the range is still a problem, as is battery weight.
It can be done, but its the "low cost/high range/high power" triangle - you can only have two.
Some v interesting things going on around this at the moment - its not a kit car but look up the Tesla Model S, if it delivers what it says it will it, then its a real game changer in terms of true electric cars. For those too lasy - 300 mile range, 0-60 5.6 seconds, 7 seats, swapable battery (3 mins swap time) and 62 miles of range per hour of charge time
If my company were forward thinking enough we would all have them as company cars in 2013.... unfortunately I will just have to dream of owning one.
Rustymini
posted on 15/4/12 at 09:58 AM Reply With Quote
Since I started this thread I've done a little research. One of my main aims was to do this on the cheap (using a fork lift motor) however there seems to be a lot of contradictory information about these (some love them, others say they're pretty useless). Buying a new electric motor seemed totally cost prohibitive. I have to admit that saving the planet is not my first aim, I just want to see if I can do it. For batteries I was going to use second hand deep cycle from a caravan breakers.
I live about 4 miles from where I work so range wouldn't be a problem as with a normal payload of a wife, two kids and a Dalmatian a two seater wouldn't be my main car.
There also seems to be arguments for and against AC or DC motors. I've found a site www.arcvillage.org which has converted a Fiat 126. Does anyone have an idea how much a Locost weighs? Taking off the weight of an engine and adding an electric motor and batteries I'm guessing that it must be similar to a fiat 126 (aroung 600Kg). This site says it can supply everything for £1600 (batteries extra). That is using a 12Kw motor. I've no idea whether that is AC or DC, or what 12Kw equates to for performance.
Are electric cars subject to the same IVA rules as petrol cars?
I'll post again when I've researched more.
Rustymini
posted on 15/4/12 at 10:13 AM Reply With Quote
I've just had a look at some old posts about Locost weight. Seems to be anything between 450 - 650Kg so going for a sub 600Kg target weight shouldn't present too much of a problem. I'm assuming about 90Kgs for the batteries and for the petrol engine to be slightly heavier than the electric motor. Also I would save the weight of the radiator, fuel tank and fuel. Add on an electric heater/demister. I'm probably looking at a very similar overall weight.
scudderfish
posted on 15/4/12 at 10:43 AM Reply With Quote
12kw is circa 16hp
Rustymini
posted on 15/4/12 at 11:24 AM Reply With Quote
Thanks for the info.
I think that's going to be far too underpowered. I don't expect to race it but I would expect it to hold it's own against a milk float.
Back to the drawing board.
Rustymini
posted on 15/4/12 at 11:44 AM Reply With Quote
Just had a look at the Electric MEV. Apparently that had a 11 Kw 3 phase AC brushless motor. However it only weighed 290KG. Looks like grinding down my welds and losing a bit of my own 16 1/2 stone.
chris-g
posted on 15/4/12 at 12:07 PM Reply With Quote
Found this on Youtube its an electric conversion of an Audi A2. Think there is use full info there.
http://www.youtube.com/watch?v=tKwYMIIJP5E
WanchaiWarrior
posted on 23/4/12 at 11:22 PM Reply With Quote
Check out this page as well, an electric Birkin.
http://www.birkin.com.au/electric-birkin-s3-for-sale.php
ettore bugatti
posted on 3/5/12 at 08:39 PM Reply With Quote
EValbum.com is a great starting point to look for motors and batteries combinations and their performances.
For example this one:
http://www.evalbum.com/2971
Simon
posted on 3/5/12 at 09:07 PM Reply With Quote
Saw these at Brighton Speed Trials a couple of years back and they were great but, for charging the batteries, I heard the analogy of having the kettle on for 25 hours
As I only live three miles from work and spend most of my time within that radius I looked into the possibility of converting a golf cart to be road legal - would need decent tyres, dual circuit brakes, parking brake, lighting and a couple of other mods, but as a way of getting an electric road vehicle, prob the best way forward (and you could have a huge fold up solar panel on the roof for when parked, maybe a fold away wind turbine too
Simon
TAZZMAXX
posted on 3/5/12 at 09:09 PM Reply With Quote
Not entirely relevant but this shows what can be done. The car is called White Zombie.
http://www.plasmaboyracing.com/whitezombie.php
