Author: Subject: help needed
loughlin1
posted on 3/4/12 at 05:59 AM Reply With Quote
help needed
I have a cable going from the battery to the starter and then a smaller cable going from the same bolt to the alternator.I have a smaller cable coming from the alternator to the ignition.BUT how do i wire the coil,which point on the coil ,where does the wire come from help please.
wylliezx9r
posted on 3/4/12 at 07:41 AM Reply With Quote
Might help if u tell people what engine you are using.
George Best
loughlin1
posted on 3/4/12 at 07:52 AM Reply With Quote
sorry a 2lt pinto
Daddylonglegs
posted on 3/4/12 at 08:48 AM Reply With Quote
+Ve on coil to switched ignition +12V and negative on coil to distributor trigger wire (which on mine also goes to the Rev counter)
[Edited on 3/4/12 by Daddylonglegs]
snowy2
posted on 3/4/12 at 06:49 PM Reply With Quote
Check out and read this....an article i wrote a few years ago. it will help you. it was done from my pinto powered car.
http://www.andersensmith.freeserve.co.uk/wiringloom6.pdf
Can some one pin this article on here? i am sure it will help loads of folks.
sometimes you are the pigeon, most of the time the statue.
loughlin1
posted on 3/4/12 at 09:11 PM Reply With Quote
that is what i need many many thanks i have already a large cable to the starter and from there another cable to the alternator,also i have a small cable from the alternator heading back to the starter switch but not fitted yet,just to put the cable on the coil and a cable from it to the distributor many thanks again
