New Topic New Reply
Author: Subject: Fisher chassis suitable for V8 & T5 'box?
itiejim
posted on 5/4/12 at 01:49 PM Reply With Quote
Hi folks,
I have a TVR AJP V8 engine in the garage that I'd like to shoehorn into a decent kit car chassis, but could do with some advice on where to start.
The TVR engine is very compact and light, if a RV8 will fit then this will, it's smaller and weighs a good deal less.
Clearly I want to create a beast - but one that can be tamed! Therefore I need something which can be made to handle well.
Having has a Fisher Fury in the past I was keen to use one of them, or a Stuart Taylor chassis of some sort as I have confidence that the geometry works properly and I suspect that an open bodied car wouldn't really be so suitable for a very high powered car.
So, can anyone give me any advice on what I can - or can't - use?
Finally, is it still possible to buy new Fisher chassis or have they disappeared?
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 5/4/12 at 01:56 PM Reply With Quote
Fury chassis are still available from http://furysportscars.co.uk/ .
The chassis would have to be altered to take a t5 box as its designed for a type 9 which is fairly narrow.
itiejim
posted on 5/4/12 at 02:03 PM Reply With Quote
That's great, thanks for the steer.
I'll ping them an email and see if they can help.
FuryRebuild
posted on 5/4/12 at 02:05 PM Reply With Quote
Last time I spoke to Steve, he was currently modifying one to take a S2000 engine and box, and the box is wide on that one (6 speed). I think he'll be keen to help you.
www.furyrebuild.co.uk
itiejim
Just one other thing...
What diff options are available in the Fury which are likely to put up with 400bhp and 375 lbs/ft of torque for a while?
itiejim
posted on 5/4/12 at 02:08 PM Reply With Quote
That sounds promising, those engines and boxes are avaialble for reasonable money now and would really suit a Fisher. I wonder what diff he was planning on using?
scudderfish
posted on 5/4/12 at 02:20 PM Reply With Quote
A Rover V8 with an LT77 definately fits, I've got one I'm in the process of swapping my SD1 3.5 V8 for a 4.3 from a Griffith. My chassis is different to the usual 4pot/sewing machine one as the tunnel is quite a bit wider and the footwells are narrower to allow for the bellhousing. I have an Atlas live axle from a V6 Capri, but I'm not near your power/torque figures.
Regards,
Dave
itiejim
posted on 5/4/12 at 02:29 PM Reply With Quote
Ahh, glad to see I'm not the only V8 nut. That 4.3 will be lovely, it was the sweetest RV8 that TVR made IMHO.
JekRankin
posted on 5/4/12 at 04:06 PM Reply With Quote
I think there is a Sylva Phoenix out there with an AJP V8, though I don't have any details. You might be able to track the owner down if you ask on the owners' club forum at www.jpsc-online.co.uk
Jek
itiejim
posted on 5/4/12 at 06:23 PM Reply With Quote
Thanks, I'll check out over there.
New Topic New Reply
