Author: Subject: Fan control wiring
zekill
posted on 6/4/12 at 08:34 PM Reply With Quote
Fan control wiring
Hi all,
someone know diagram wiring for this fan control ?
there is 3 wires:
- red .......... 12v ?
- black ....... 0v ?
- blue ........ hearted when temp is match setup ?
thank.
Fan control
Fan control
Fisher Fury with Phoenix bodywork, Blade 919cc
hicost blade
posted on 6/4/12 at 08:36 PM Reply With Quote
Does it have a relay?
zekill
posted on 7/4/12 at 06:54 PM Reply With Quote
there is a relay socket at the end but wiring seem to be modified.
zekill
posted on 28/4/12 at 05:40 PM Reply With Quote
Well,
I write the solution for others have the same part:
This is the electronic Fan controller sell by RD and others.
3 wires:
red: to +12v
black: earth
blue: earthed when fan must start, use this to control a relay.
snowy2
posted on 29/4/12 at 05:38 AM Reply With Quote
Bonjour.......
Your wiring sounds about right, it must have a live feed for the thermostatic switch plus a wire to the fan (or more usually a relay to switch the fan on) and of course the whole thing must be earthed. This may help your wiring, you just need to add your earth wire to my drawing...
http://www.godspeed.me/forums/viewtopic.php?f=14&t=1289
It is a method on how to wire up a thermostatic fan switch with a relay and also have an override switch on the dash (for when you get paranoid) the wire to the relay would connect to pin 85 on the drawing.
sometimes you are the pigeon, most of the time the statue.
zekill
posted on 29/4/12 at 06:43 AM Reply With Quote
thank you.
I have too add a switch to control fan.
All electric jobs are done in my car.
http://sylvafury.blogspot.fr/
