Author: Subject: starting engines on bike carbs
Fishface
posted on 28/4/12 at 10:21 AM Reply With Quote
Is it best to fit a choke cable for bike carbed engines or do people make do without and just take the engine cover off and mnually adjust the choke until its warmed up?
snippy
posted on 28/4/12 at 10:27 AM Reply With Quote
Never needed a choke on my bike carbs. 1 squirt of the accel pedal and it fires straight up then just apply slight revs (+500) for 15-20secs and it will tick over fine. In warm weather I don`t even need to do this!
richmars
posted on 28/4/12 at 10:28 AM Reply With Quote
Normally starts ok without choke. When I start it during the winter I use choke (only because the bonnet is off.)
kipper
posted on 28/4/12 at 11:01 AM Reply With Quote
I fitted a cable to mine , starts fine with the choke.
Denis.
Where did that go?
lewis
posted on 28/4/12 at 11:45 AM Reply With Quote
I started without but found it better with a choke fitted you can start the car & let it warm up without having to sit in it tickling the throttle to get it going.
I am a driving god!..........sort of
snapper
posted on 28/4/12 at 11:46 AM Reply With Quote
Connected choke cable to the Sierra bonnet catch under the column
I need a bit of choke to start and for 1 or 2 mins on a cold day, then it ticks over ok.
Whith the other engines with serious cams it deco needs the choke to start.
I eat to survive
I drink to forget
posted on 28/4/12 at 12:22 PM Reply With Quote
I connected the choke on my carbs - I use it to get going, then push it home after 50 yards or so (once I'm through the junction at the end of my road).
jacko
posted on 28/4/12 at 02:06 PM Reply With Quote
I have a choke but only use it for the first start of the day after the car has not stood for a week or two
