Author: Subject: Brake light switch?
posted on 7/5/12 at 09:08 PM Reply With Quote
Brake light switch?
I'm now in need of ANOTHER (3rd one) hydraulic brake light switch and am convinced a pedal mounted normal thing is better.
Hydraulic ones are in the £10~12 bracket and bleeding the brakes after changing is a real pain.
However it doesn't look easy on my floor mounted bias bar pedal set up, its welded in... its another pain in the ass as to get the bar out to drop the brake pedal means taking the body off!!! AAAAARRRRRRRGGGGGGHHHHHHHH!!!!
Anybody done this, got any pics, suggest any other way? What do the rest of u use???
Ta,
NigeEss
posted on 7/5/12 at 10:18 PM Reply With Quote
Plenty of production cars use drybollock switches reliably. What make are you using, not Fuel Parts by any chance ?
VW Polo ones are standard 10mm thread, about £20 for a genuine one.
Dusty
posted on 7/5/12 at 10:30 PM Reply With Quote
It doesn't have to go down by the pedals. Put it somewhere easy to get to. T off rear line under the bonnet. Leave the old one in but disconnect the wires.
adithorp
posted on 8/5/12 at 07:22 AM Reply With Quote
He means that he's sick of the hydralic switch failing and wants to swap to a mechanical switch instead.
Coozer, I looked at this and it's not easy with floor mounted pedals. Only ways I could work it out was by having a push rod off the back of the pedal, through the bulkhead and a switch bracket, on the engine side, being activated by the push rod. Either that or a "pull switch" set up. Both were compilcated and I've stuck with the presure switch.
http://jpsc.org.uk/forum/
posted on 8/5/12 at 09:22 AM Reply With Quote
Yep, I'm on my third switch...
If I could get the pedal out I thought about a little extension on the bottom with a mechanical switch on the floor?
Other thing I've been thinking is, would the hydro switch be better in the rear where the pressure is lower instead of the T piece at the front where the single line spilts to each side?
adithorp
posted on 8/5/12 at 09:35 AM Reply With Quote
They're supposedly better in the front as they switch sooner due to the presure. Mine is in the rear though, as it was just easier from a packaging point of view (plus I didn't think about it first). Only had one failure on mine and the current one has been in for 3 1/2 years/12000miles. So... the rear might be the way to go.
As for bleeding... My T has the switch side pointing up. I fill the hole in the switch with Girling brake seal grease to stop it having an air bubble in it then swap the switches quick. The fluid dribbles out while while swapping and if your quick then it's self bled and good to go. Just dont drop or cross thread the switch in your haste.
posted on 8/5/12 at 11:10 AM Reply With Quote
Problem is mines on the side.. I used to have it on top and it didnt work, probably due to air in the switch...good tip on filling it with grease. Wish I'd thought of that before I moved the pipes round and put it on the side.. DOH!
snowy2
posted on 8/5/12 at 11:45 AM Reply With Quote
Leave the faulty one in and fit annother anywhere its got better access. close to one of the front calipers will work fine and less bleeding afterwards.
sometimes you are the pigeon, most of the time the statue.
adithorp
posted on 8/5/12 at 12:33 PM Reply With Quote
Actually now I think about it, I poured a drop of fluid in then sealed it in with the grease. As the grease is for brake cylinder assembly it's fine in the system.
posted on 8/5/12 at 03:33 PM Reply With Quote
Just been over to Eurocarparts and they are common fitment to Vag motors over the years.
£5.45 for a FEA OEM jobbie, hope that lasts. Might as well strip the Wilwoods and clean them up while I'm on.
dhutch
posted on 8/5/12 at 04:38 PM Reply With Quote
I would be wanting to know why the wet ones where failing so much!
rost
posted on 11/5/12 at 07:42 AM Reply With Quote
Too much current through them? Are you guys using a relay for the stoplights?
Mine on the striker hasn't broken yet, but I'm running LED lights at the back, so not that much current.
Charlie don't surf!
wilkingj
posted on 11/5/12 at 08:14 AM Reply With Quote
Do not orientate the switch with the terminals uppermost. When beleeding air bubbles can collect, and then the switch may not work due to the air bubble compressing and not operating the switch.
Just my 2d's worth, and experience.
Best Regards
Geoff
http://www.v8viento.co.uk
adithorp
posted on 11/5/12 at 08:25 AM Reply With Quote
I think general concensus is "They're made in China from recycled rice waste" other wise known as "shite".
ps. I've got LED brake lights and have had one fail.
RK
posted on 11/5/12 at 12:05 PM Reply With Quote
I had a switch like that neatly mounted for ignition actuation, a safety switch that won't let you start til the clutch is depressed. The switch failed in a fairly short time. I would think the hydraulic ones are used for a good reason.
posted on 12/5/12 at 12:32 PM Reply With Quote
Right then chaps, anyone want to come round and point and laugh???
Bought another switch from Eurocarparts... cheap if anyone needs them £5.45...
Sanity check on the switch.. no voltage on the multimeter.. study the manual (dead easy when you use the sierra loom) remove the scuttle, trace the wires.. odd thing... checks the continuity OK, voltage on one side of the fuse.. wait for it..... fuse missing.. how the hell... the guys sworn they were working on the way down to Stoneleigh and stopped as we passed through the village.
New fuse in and they work fine...
Theres no way a fuse can fall out surely? And, are they all suffering form dementia behind me????
And, just to be sure they were working the time before when I had it out .. for MOT!
DOH!
40inches
posted on 12/5/12 at 12:50 PM Reply With Quote
I have used a Goodridge banjo switch ,the thinking being that it might possibly be better quality than the normal
Chinese offering.
[Edited on 12-5-12 by 40inches]
rost
posted on 15/5/12 at 07:37 AM Reply With Quote
On the fury I have this microswitch: http://hartmann-codier.de/family_20.html?id=198&lang=en
It handles 16A and has 6.3mm terminals.
I made a bracket for it that the pedal releases the switch at a slight pedal depression. If the striker's hydraulic switch ever breaks I'm converting to this too.
Both are top mounted pedals, but there must be a way to do this on floor mounted pedals too.
Charlie don't surf!
loggyboy
posted on 15/5/12 at 08:03 AM Reply With Quote
DOH!
So was the hydraulic one not faulty then?
Mistral Motorsport
bi22le
posted on 15/5/12 at 09:41 AM Reply With Quote
I have got a hydraulic switch in the rear plumbing with the terminals upwards. It takes a lot of force before the brake lights come on. I have bled the brakes at the switch due to the previous bubble compression problem but its still the same.
Can you get more sensitive switches or should i T and put a switch on the front instead.
Dont mean to hi Jack the OP but this may be related or help. I will start another post if requested.
I Dont want to mount another non hydraulic switch as this system almost works for me.
Cheers.
Biz
Please read my ring story:
loggyboy
posted on 15/5/12 at 10:02 AM Reply With Quote
My Raw supplied brake kit comes witha 3way adapter to use at the front only a few inches from the M/C. With the supplied brake line lengths, I see no option but to mount it facing up, but seems the better way is to have it pointing down.
Mistral Motorsport
posted on 15/5/12 at 10:19 AM Reply With Quote
No, as I said the fuse was missing from the fuse box!
bi22le
posted on 6/8/12 at 06:13 PM Reply With Quote
Hi Coozer,
You were right with the switch and I have replaced it.
It now works perfectly woohoo!!
I have updated this for reference. Future searching \ fountain of knowledge and all that jazz.
The brake light switch was faulty and replacing it with a new switch from Eurocar parts FAE 464550020 fixed the sensitivity problem.
Biz
posted on 6/8/12 at 07:52 PM Reply With Quote
How to change a hydraulic brake light switch.
(1) Assistant is required.
(2) Slacken or remove master cylinder lid.
(3) Assistant gently presses the pedal while you slacken the switch Use cloth to absorb fluid commong out.
(4) Assistant holds pedal down.
(5 Screw new switch on and lightly tighten.
(6) Assistant can let pedal back up.
(7 As you slacken switch a couple of turns your assistant gently presses pedal down and holds it down.
(8) While assistant holds pedal down fully tighten switch.
(9) Assistant releases pedal.
(10) Top up reservoir
(11) Assistant presses pedal hard while you check for leaks.
posted on 6/8/12 at 07:56 PM Reply With Quote
