Author: Subject: Racetech 0-8 bar oil gauge sender issues
mark w
posted on 8/5/12 at 10:56 AM Reply With Quote
Hi there, I'm currently trying to purchase an oil pressure sender for an earlier (older) type racetech gauge. I did purchase a gauge & sender but it is the newer version, since then I've managed to buy an older style gauge to match my water & fuel gauges but the new style sender is not compatable as the resistances are wrong & my gauge reads 7 bar without the engine running! Anyone know the correct resistance of the original? Or where I could get 1? Cheers
femster87
posted on 8/5/12 at 11:42 AM Reply With Quote
Sorry not a direct answer. But I bought a VDO one for my racetechnology dash. It has a 1 - 10bar range. And can be calibrated with the resistance. That might be your only option if you can calibrate the dash. They do a range of them.
[Edited on 8/5/12 by femster87]
