Author: Subject: MK2 Escort Workshop Manual - anyone got one?
encyd
posted on 19/5/12 at 02:56 PM Reply With Quote
A long shot but does anyone have a MK2 Escort Workshop Manual?
I'm trying to rebuild my master cylinder and of course it's nothing like the one in the haynes manual but after some searching online I've found this advert on ebay: FORD Escort MK2 &RS200 Brake Master Cylinder Repair Kit | eBay and the manual in the background that I can't really read is identical to my master cylinder! Looks like either page 126 or page 136.
I've got it all apart and have some spare seals but I'm damned if I can work out how to remove one of the springs and I'd really rather not break it! Of course this is the only seal which has any real wear showing too
I've added a pic of the bit I can't get apart on dropbox here: https://www.dropbox.com/s/ww91y9y7phl422x/IMG_6647.JPG
Neil
[Edited on 19/5/12 by encyd]
slingshot2000
posted on 19/5/12 at 04:12 PM Reply With Quote
I have a MK2 Haynes here, let me know what you need and I will try and sort it for you.
You also have a U2U
Kind regards
Jon
NigeEss
posted on 19/5/12 at 04:35 PM Reply With Quote
Is there a pin through the hole you can see inside the spring on the left hand end ?
JeffHs
posted on 19/5/12 at 04:54 PM Reply With Quote
From Haynes
'the secondary piston is secured to the spring retainer by a tab which is engaged under the piston front shoulder. Lift the tab to remove the piston. Compressing the spring, move the retainer to the side and detach the secondary recuperating valve stem from it. The valve spacer, washer and seal can then be slid from the valve stem
Clesr as mud!
encyd
posted on 19/5/12 at 05:15 PM Reply With Quote
You also have a U2U
Kind regards
Jon
Hi Jon,
Thanks for the offer - is it the one with the blue cover (Ford Escort '75 to '80)? If so, I've got the same one here and unfortunately my cylinder looks nothing like the one in the Haynes manual.
Neil
encyd
posted on 19/5/12 at 05:20 PM Reply With Quote
Good thinking! I've had rotated the shaft through 360 with the spring compressed and I can't see anything that I could poke out
When the spring is compressed in either direction I can move the cylinder with the holes in on the shaft and the shaft stays firmly fixed to the piston on the right.
I'm wondering if there is a thread on that piece and it unscrews somehow? That wouldn't be ideal inside the cylinder though if it worked loose. It must come apart since the servicable items are a shim and a seal, the seal might be able to stretch over but the shim certainly can't!
Neil
encyd
posted on 19/5/12 at 05:24 PM Reply With Quote
Originally posted by JeffHs
From Haynes
Clesr as mud!
Thanks but I don't think my cylinder is the same as the one in Haynes. It's a Girling tandem one with dual outputs for the front brakes and a single going to the rear. It's got a 3/4" bore and was apparently used on 1100/1300 Escorts with front discs and rear drums but with no servo from 03/1977 through 1980.
Hmm, so I can compress the spring to the left in my picture and the spring reatiner is loose on the shaft and I can then slide the seal and shim up the shaft but can't see any easy way to remove it.
jwallbank
posted on 19/5/12 at 10:47 PM Reply With Quote
Not sure if this will help but its from the Mk3 Manual:
[img][/img]
John W
encyd
posted on 20/5/12 at 07:32 AM Reply With Quote
[img][/img]
John W
Hmm now that does look very similar, I certainly have no screw/bolt head that I can undo with anything conventional but it's got to be worth investigating. Thanks for the pic!
Neil
Cornishman
posted on 20/5/12 at 06:31 PM Reply With Quote
From the 75-80 RS2000 and Mexico manual........
There are 2 types , "A" and "B".
Type "A" has already been covered in someone elses reply, but is yours type "B"?
This has "shims" according to Haynes. It can be identified by the fact it has a piston stop screw on the top under the reservoir.
The manual states....
"pull the reservoir from the cylinder and remove rubber plugs
Push the primary piston down into the cylinder to release its tension against the circlip and then extract the retaining circlip.
Unscrew the piston stop screw from the top of the master cylinder.
Extract the primary piston assembly together with the stop washer.
The secondary piston can now be removed from the cylinder by applying a controlled amount of compressed air into the front hydraulic outlet connection. The spring can be shaken out."
The manual goes on to describe a "special screw" that holds the primary piston assembly together, is this what you are having trouble with? When reassembling it states that this screw must not be overtightened?
If you think that this is similar to yours I could maybe try to photograph it ?
encyd
posted on 20/5/12 at 09:03 PM Reply With Quote
Thanks for this, hmm reading this mine does sound very much like the type "B".
I've since managed to remove the spring from piston, it was a rounded off 2.5mm hex shoulder bolt in the end holding it on. It's not in too bad nick once I got it out, I'm guessing someone in the past had some trouble removing it! Just looking down the hole and trying a 2 and 3mm hex key I got no grip.
Steve - if you wouldn't mind taking a photo I'd be interested in having the diagram for future reference.
Thanks all for the replies, been really helpful
Neil
Cornishman
posted on 22/5/12 at 07:17 PM Reply With Quote
Heres the diagrams ....hopefully!
[img]http://[/img]
[img]http://[/img]
[img]http://[/img]
encyd
posted on 25/5/12 at 04:48 PM Reply With Quote
Awesome thanks for that!
