Author: Subject: The time has come...
andyps
posted on 21/5/12 at 09:52 PM Reply With Quote
... for me to really admit that for the foreseeable future, just as the last few years have been, I will not have time to put together a Locost. Because of this I guess that I really should sell everything I have so I can make some space and then hopefully sometime in the future start again.
Essentially what I have is a large portion of the parts to put something together, but not much of it has been put together yet. I started building a chassis from scratch, original Ron Champion Locost dimensions as far as behind the seats but 2inch taller to accommodate a range of engines. I also built a front suspension mounting for rocker arm suspension based on MK Indy suspension geometry. My plan was to put either a McSorley or Haynes Roadster rear end for IRS on it, but I have only built it as far as the rear bulkhead. The chassis is only tack-welded so far.
In terms of parts I bought a good, running 2.0 DOHC Sierra so have all the mechanicals from that, along with alloy front hubs I bought from MNR to replace the originals.
Other items I have (and there may be more but I can't remember and need to check) are;
MK Indy front wishbones, slightly used
MK Indy rear arches, slightly damaged but repairable
New front arches
Lolocost nosecone, unused
Pair of seats from a Bedford Rascall
Caterham roll cage
More complete rollcage with downbars and a diagonal
Windscreen from both a Caterham and an Avon Tiger
Caterham headlights
Ford Escort Mk2 steering rack
Lots of little bits and pieces.
I think I spent around £1000 in total for all these parts etc. and ideally would like to sell everything as a job lot to save time of individual listings and despatch. If anyone is interested make me an offer, I'm not prepared to give it away but really need to have a clear out so make a sensible offer based on the above items. Contact me by PM and I will keep an eye on this post.
andyps
posted on 13/5/13 at 02:08 PM Reply With Quote
OK, so it is another year later and my garage is still full of Locost parts so thought I should try again and see if anyone is interested. As before I would ideally like to sell the whole lot in one go but am open to offers for any of the items I have so let me know. By my reckoning I have around 90% of the parts needed to complete the car, certainly no major bits needed so it would be fittings and so on which would need to be purchased to get everything - and I even have some of those.
Go on. you know it would make life easy to get the whole lot at once!
emwmarine
posted on 13/5/13 at 03:00 PM Reply With Quote
Just my opinion. I think the only/best way you will shift this stuff is to list it all separately on ebay. Maybe put some of it on here first but each item with individual price tags.
The Ford DOHC wont be that popular. I got 40 quid on ebay for a low mileage one.
Building a Dax Rush.
andyps
posted on 13/5/13 at 03:48 PM Reply With Quote
I think you are right, but if someone wants a project without the hassle of searching everything out this would be great and would be much easier for me, even if I end up with a bit less in total I'll be happy. If there are no takers I will list things separately though.
Mk in MK
posted on 13/5/13 at 05:05 PM Reply With Quote
Is there a "performance" type tubular manifold to suit the DOHC engine?
JF.
andyps
posted on 13/5/13 at 05:17 PM Reply With Quote
JF.
I do have a tubular manifold for the DOHC engine, what it does to the performance I don't know, but it looks like it should be OK with pretty much equal length pipes (I haven't measured them).
Jamster1233
posted on 14/5/13 at 03:49 PM Reply With Quote
do you have a bonnet ? if so can i buy that ? in a big need of one have been for 4 months :-(
andyps
posted on 14/5/13 at 04:44 PM Reply With Quote
I do have a bonnet, think it might have been from an MK but can't remember, I do know it is blue though!! And yes, I would be willing to sell it.
andyps
posted on 20/5/13 at 07:41 PM Reply With Quote
Quick bump for this, I've had some enquiries for individual parts but before I start listing everything separately thought I would have another mention for a job lot!
Mark100
posted on 20/5/13 at 09:38 PM Reply With Quote
price for nose cone and how wide are the front arches
andyps
posted on 20/5/13 at 10:41 PM Reply With Quote
U2U sent, I'll measure the arches tomorrow and let you know.
